Notices
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
1995 240SX – LS6 w/ built 4L80E w/ Transbrake, Kouki Conversion w/ Fresh Paint
Old 06-18-2018, 08:39 AM
hennajapagaijin's Avatar
Default 1995 240SX – LS6 w/ built 4L80E w/ Transbrake, Kouki Conversion w/ Fresh Paint
Year: 1995
Make: Nissan
Model: 240SX
Price: $17500
Mileage: 164100
Location (State): VA
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Contact: LS14auto(at)gmail(dot)com
Full Album: https://imgur.com/a/FScAQRO
Price: $17,500 or best reasonable offer, No Trades
Brief history:
I purchased this car in 2005. At the time it was mainly stock but had a stock SR20DET with a knock. I was able to drive it home, pull the motor and replaced it with another stock SR. I eventually upgraded to a GT30 with supporting mods and had the old SR rebuilt with upgraded internals/components. Around this same time in 2007 I suffered an injury that prevented me from driving a manual. I thought about selling the car then, as it was my second/project car, but instead decided to pursue an automatic option that would allow me to drive it. Below is the result, a purpose built car that has a lot more potential because of the quality and ‘beefiness’ of the parts used and attention to detail.
This car was finished in August 2015, but has mainly sat in my garage the past three years, hence the reason why it’s time to sell it. In that time I have put less that 1,200 miles on it, and 600 of that was driving from Louisville, KY to D.C. Also, it has never been to the track since I’ve owned it.
I covered the main areas, but I am sure I am leaving a few things out. Please feel free to message me with any questions.
Details:
1995 240sx with 164,100 on chassis
Kouki Conversion, bodywork, and custom paint (160 total hours) by Phantom Autobody
Powerplant and Drivetrain:
LS6 from a 2001 ZO6 with 46,000 miles
FAST ELECTRONICS 102mm intake w/ Professional Products complete Fuel Rail Kit
Jake’s Performance Stage II 4L80E w/ Trans Brake, custom trans mount, and tranny cooler
Jake’s Performance custom converter (Stall 3500/ Shift Point 6600)
Sikky mounting kit/custom oil pan/headers/power steering/etc
PSI custom harness, reflashed PCM, DBW and ISS enabled for 4L80E
Q45 LSD Diff Final gear ratio: 3.54 / 300ZX TT Driver Side Axle (installed on driver side of 240SX) and Infiniti Q45 Driver Side Axle (installed on passenger side of 240SX).
Koyo Radiator
Suspension:
APEXi N1 ExV Coilovers
Energy Suspension Hyper-Flex complete bushing replacement
SPL SOLID Differential Bushings
SPL SOLID Subframe Conversion Bushings
Brakes/Wheels/Tires:
CTS-V front brake calipers with 13” Mitsubishi Evolution Evo 8/Evo 9 Performance Brake Rotors (Front)
300zx rear brake caliper with Power Stop K666 Rear Ceramic Brake Pad and Cross Drilled/Slotted Combo Rotor
Enkei RPF1- Racing Series 17x9.5 18mm Offset (rear) 17x8 (front)
Yokohama S.Drive High Performance Tire - 255/40R17 94Z and 235/40R17 90Z
Electronics and Misc:
AEM Wideband
AEM oil pressure gauge
12” electric fan with thermostat
Optima Batteries RedTop Battery relocated to the trunk in xx battery box
T-Spec V12-CBF140 V12 Series 140 Amp Circuit Breaker
Walbro 255lph In-Line Fuel Pump
New Brake Master Cylinder
New rear glass and several pieces of rubber trim replaced.
I tried to be as thorough capture the known issues in the Imgur album with photos and descriptions, most are very minor, but wanted to be as transparent as possible. Here is a summary:
Two hairline crack in the brake light (was like that when I bout the lights)
Drivers seat lumbar worn through
1/4” scratch and small dent in paint above driver’s side rear wheel, which is very minor, but the most significant s issue with the paint. There are ~2 other minor blemishes from in the front bumper area/hood from road debris, but barely noticeable and unable to capture in a picture. Other than that, the paint is pristine.
No A/C
No trim around shifter
Crack in trim below radio
Crack in passenger’s side door handle trim
Radio currently doesn’t work and I have a replacement I will swap or give to new owner.
Discoloration on sunroof trim, sunroof is functional and no leaks.
Discoloration on windshield wipers
Gop of back seat has a few small cracks in the leather
Two small surfaces area rust spots in trunk
1/8" cut in passengers side door
glued seem behind drivers seat separated
Old 06-19-2018, 12:32 PM
Kembo's Avatar
Default 240sx
Really nice build. Wanted to know if car originally came with A/C ? Do you think there is room in the engine compartment for a compressor to be installed, it looks kind of tight in front of engine Thanx
Old 06-19-2018, 04:22 PM
Thank you!
The car did come with A/C and the A/C worked on the old SR setup. There are modifications that go into keeping the AC on this type of setup and a full write-up can be found here: http://www.rigidracing.com/2013/09/0...complete-post/
Also, Sikky makes an A/C adapter kit that apparently makes the install easier.
Old 06-28-2018, 05:31 PM
Default Video From Today
0:01 – Start up
0:11 – Walk around while running
0:52 - Transbrake demonstration
1:11 – Another quicker transbrake because traffic behind me
1:24 – Brief pull on the high
Old 07-15-2018, 09:04 PM
Car is now listed on ebay
Old 07-17-2018, 07:53 AM
hgiles's Avatar
Default Love it!
Great car! Trying to decide if I can live with the auto trans though.
Old 07-18-2018, 10:25 AM
jmilz28's Avatar
Great build. Too bad there's no AC, that all but removes the South, including TX and FL, as possible markets because it makes it a toy instead of a practical driver. Consider making that investment if possible. I think you made a good call with the 80e, keeps millenials in the running. Also makes it better suited for the drag strip. Nice clean work, GLWS.
Old 07-22-2018, 12:29 PM
Completely understand. As Jake says on his website, the 4L80 is not for everyone, but it is the unit of choice if you plan to make serious power. That was my eventual plan; unfortunately, I never got there. However, the car is now set up for someone else who wants to go that route. Sale ends in 9 hours. Thanks!
Quick Reply: 1995 240SX – LS6 w/ built 4L80E w/ Transbrake, Kouki Conversion w/ Fresh Paint
