1984 K10 w/ 2001 LM7 Build
Hello fellow swappers! I'd like to introduce you to my 1984 K10 Custom Deluxe. I’ll try to keep this concise but still hit all the important details.
My grandpa bought this truck brand new from Berger Chevrolet in Grand Rapids, MI. It was his daily driver for many years. Pulled a camping trailer to the campground every summer, and after retirement, it's what he and my grandma drove to Florida for the winter. That's the reason it has over 457,000 miles on it. He pulled the original 305 somewhere around the ten year mark and replaced with a 350 that he built. Best guess is, the current motor has over 350,000 miles on it. Still holds 40 psi of oil while cruising.
Time passed by, and eventually grandpa was no longer able to drive. Rather than sell it, he chose to pass it on to my uncle Bob. From what I understand, he only used it occasionally. Mostly to pull a boat to the water. Eventually Bob upgraded to a larger boat that just stayed in the water. This left him with very little use for the truck. So he offered it to me, on one condition; I could never sell it. It had to stay in the family. Considering I've got two rambunctious little boys, it shouldn't be hard to find someone willing to take it when the time comes
Of course I was all over that deal! Only one problem... I live in Tucson and the truck was in Grand Rapids. 1900 miles away. Shipping that far is crazy expensive, and I couldn't really take the time off of work to fly out, then drive it back. Plans stalled.... Until....
My father in law, told me he bought a utility trailer in Michigan, but didn't have any way to get it back to Tucson. Light bulb! Long story short, he drove his Cadillac to Michigan, sold it, then drove my truck and his trailer back to Tucson. The plan was perfect. The execution was less that perfect though. Carburetors, elevation changes, hot weather, bla bla bla… It ended up taking him over a week and a couple nights in hotels to make the trip back.
Here she sits in my parents green front yard, prior to the 1900 mile drive.
And after the 1900 mile drive and a quick wash
The almost original (soon to be gone) 350
The truck runs and drives good enough, it just won’t pass emissions without some ethanol blending. Not worth the hassle to me. That’s all the reason I needed to do a swap. This won’t be my first swap either. I have a 1997 S10 RCSB with a 2002 LQ4. Youtube review:
The donor vehicle. A 2001 GMC Yukon.
That’s it for now. I’ll post regularly with updates. I’ve been a member here for a while and found answers to most of my questions just by searching. Even had a couple questions answered in a thread I started. Thought it might be time to contribute some content, Here goes!
That brings things up to current time, more or less.
Waiting on some trans maintenance parts (dipstick seal, torque converter seal, turbine shaft seal, transfer case adapter gasket and filter), so I started in on the engine. Stripped the harness off.
This one's pretty gross. Going to take a couple passes with the SuperClean and pressure washer.
My plan for the engine is just regasket, cam, springs and slide it in.
After a couple hours of spraying cleaner, scrubbing, then spraying with the pressure washer, I called it good enough. I think I ended up wearing half of what came off the motor, but it was worth it.
There's still a little crud in some of the nooks and crannies of the pan and on the screws for the front and back cover. I'll take care of that when I pull it apart for gaskets. The block and heads are clean and that was my main concern.
Now I just need to drop about $200 on gaskets to keep it this clean.
Cool story and project. I love seeing these square bodies getting the LS treatment and am gathering up the stuff to put an LQ9/4L65E from an '05 Escalade it to my '84 K5 Blazer. Post up any questions you have there's a lot of knowledgeable guys on here that can help you figure stuff out.
I sold the T-case for $370. That's almost enough to cover the total cost of a cam and springs. I'll be ordering them SOON!
cool swap. you're still at the stage where you can stop and heed the words of those who have been there and done that, dump the 60e. 80e backed with a 241 from an 89-91 blazer or suburban. you'll have to get new shafts made, but you'll be money ahead in the long run.
4L80 is definitely a stronger trans and a good idea if you're going to be running big tires and/or more power. That being said your 4L60 should do fine with a stockish 5.3 and the smaller tires in your pics. As far as mating up the 208 goes, they should bolt right up (same spline count and 6 bolt pattern like you said) but getting a VSS is a different problem with a few options. Jags That Run and Dakota Digital both make in-line pulse generators that screw in to the mechanical speedo hole on the t-case and output a VSS signal. Pretty sure Advanced Adapters also make a replacement trans to t-case adaptor that comes with a tone ring and has a spot for a VSS to screw in that'd do the trick. Or do like truckdoug mentioned and get a 241 out of a 90-91 Blazer or Suburban (89 had a mechanical speedo still) that have the VSS which might wind up being cheaper than the other options I mentioned if you find a good deal at a wrecking yard or on Craigslist. If you go that route try to grab the gauge cluster as well since the 90-91 trucks had electronic speedos as well. I was able to find a 90 Burb at a Pick-n-Pull and got the 241 and gauge cluster for under $200.
I even have one in my S10. Let's be perfectly honest though. This motor is going to be naturally aspirated with a mild cam. The truck might go
off road at some point in the future, but it'll never be a hardcore wheeler. Max tire size will be 31" and the heviest thig it will ever tow is a
car dolly. The 700r4 that's in there now was recently rebuilt, but before that it had over 200k on it. I'm sure the 60e will be fine. When it
gives up the ghost, I'll rebuild it. I appreciate the feedback!
Alright. Here's my day in pictures. Might be slightly out of order.
Trans parts arrived.
Slammed them in.
Had to pull out the special J-tools
Pan looked okay. Magnet was full, but no chunks or flakes so I'm happy.
Cleaned up nice though.
That completed the trans work.
Turned my attention back to the engine. Pulled the plugs.
Then pulled the manifolds. The only hiccup was one broken bolt. Came right out with the vise grips. Couple of the bolts felt only hand tight(?).
Going good so far though. Dipstick tube even cam out without a fight.
Cleaned up the gasket surfaces. Probably better than they need to be, but it makes me happy.
Also ordered a new oil filler cap with the trans parts. Old one didn't fit tight and for whatever reason that really bothers me.
Peeled the VC's off. Not the cleanest top end ever, but I've seen far worse.
Definitely the source of some of the exterior oil.
That was it for today. Last night I orderd a bunch of engine gaskets and spark plugs. Should have them middle of next week.
I also think I've settled on the Elgin 1838 cam. Just not 100% sure what springs to run. Leaning towards the PAC 1215's. They tolerate 0.600"
lift (the cam only has a max lift of 0.560") and a seat pressure of 105 lb at 1.800". I know LS6 springs are cheaper and people have had success
running them on a 0.560" lift cam, I just don't know if they have enough seat pressure.
Nice work so far getting everything cleaned up. That's something I still need to do with my setup that's sitting in the garage, I just keep putting it off until our contractor gets his stuff out so I can have room to work.
What were you planning for tires and gears? That cam would be good for a lighter 2wd but might shift the powerband too high for a heavy 4x4. You could always take a look at the Cam Motion or Brian Tooley truck cams. They have versions specifically made for the smaller truck engines and are designed to use the cheaper LS6 springs you mentioned.
What were you going to do for the exhaust? Seems like the factory truck manifolds hit our frame but TBSS or LS3 Camaro manifolds fit real well. For headers I think the Schoenfeld 1302LS1, Thorley THY-323Y-C, and the BRP muscle rods are the only ones labeled as working with 4x4 trucks.
The Stg I cam is our entry level cam for use in practically any LS engine where great low speed torque is desired. With it's narrower LSA, this cam will make more low end torque than a production LS6 cam will.
That's why I was asking about tire size and gearing, the 3.73's and 31's might actually pair really well with that especially if it's going to be mainly street driven. If you were running 35's with 4.10's in the mud and sand or something like that then you'd want to try to keep the power band lower to maximize the grunt to turn those heavy tires.
I've seen some of the 2wd guys have luck with the Camaro stuff but if I remember right the 4x4 guys had issues with them contacting the shackles and or something like that. For $156 they could definitely be worth rolling the dice on them. I think I'm learning towards the $260 painted Schoenfelds so I can have v-bands installed with the exhaust to make it easily removable.
Hey Brandon, what is the tape you have over the intake ports on the heads? My LQ4 is worse that the before pics of yours,
and I've been leary of power washing it without something that will stay in place.
My grandfather had an 80 Custom Deluxe 20 (Brown/white with a tan interior) When he passed in '94 it was still in great shape
with only minor rust for a MI vehicle. My uncle asked my Grandma if she wanted to sell it, and if so to get a price.
She looked at KBB and it didn't go back to '80, so she looked up the oldest they had listed and used that as a guide.
The truck only had 34k on it and dual tanks/towing package. She told my uncle "Five" (meaning $5k) and his friend who bought it
showed up with $500 and SHE SOLD IT TO HIM! I would have bought it for more than that if I'd known she was going to sell it.
Now, when I need to tow something, my GF's dad lets me use his '03 Sierra crewcab Duramax w/ 60k miles on it.
I'll be following this thread. I followed it over from S10forum.
Jay
Jay
Looks like black duct tape, only tougher.... OK I want to know too! lol
