Is this head salvageable?
Use 'em! A light skim will take those out.
For porting, just do a good bowl blend. That's where most of the gains are to be had with these heads. And don't worry about polishing. Almost nobody does that anymore. Check all the CNC jobs that flow the big #'s. No polishing.
Tell the seller you think they won't work, but you'll give him the benefit of the doubt, and pay him TWICE the scrap value. (which is what... $15 or so for the pair?)
Then just bolt em up and run em. Those are in places that totally don't matter. Only thing is, if there's a burr of metal thrown up around em, grind that down flat REAL CAREFULLY so the burr doesn't keep the gasket from laying flat on the surface.
thanks guys. I was able to clean up a lot of the carbon build up but the 2 exhaust valves in the center of the head has some hard pale white on the dish that I just cant seem to remove. I tried soaking them in acetone overnight and tried a nylon bristle wheel and it wont even come off. It even looks like epoxy of some sort? no current pics but its the 3rd pic in post #3.
