Convertible Vehicles Enthusiasts | Information | Maintenance
Weird mark
Old 02-28-2019, 09:41 PM
Carguy8888's Avatar
Default Weird mark
I don't know how but this could be a wear mark, the nice people at Meguiars were stumped. I cleaned the top with their Ragg Top cleaner but it did not come out.. Anyone ever see this mark?
Old 03-01-2019, 06:58 AM
JohnnyBs98WS6Rag's Avatar
Maybe its just me, but I don't see a photo of any mark. I'll check this thread when I get home.
Old 03-01-2019, 07:02 AM
Carguy8888's Avatar
If you can see the picture of the top there is a white line going across it where the belt molding is.
Old 03-03-2019, 06:49 PM
Carguy8888's Avatar
Bump for another try.
Old 03-04-2019, 09:27 AM
Chevyguy2001's Avatar
My 2000 SS has the same mark, but its not as white as yours.
Old 03-04-2019, 09:31 AM
Carguy8888's Avatar
So it's a wear mark, any idea how this happens?
Old 03-04-2019, 09:42 AM
qweedqwag's Avatar
Probably friction from rubbing, I have seen vinyl do that from heat, I used a hair dryer on it lowest heat setting and removed the discolored area, it brings the oils back to the surface.
Old 03-04-2019, 11:49 AM
Carguy8888's Avatar
Wow, I've never seen this before. I'm sure your hair drying method is not going to work on floor so I guess I'm just going to leave it.
Old 03-07-2019, 08:09 PM
I see the photo now. Looks to me like water got in while the top was down and dried up leaving the stain. I'm pretty sure that end is down and the top folds back over the window when the top goes down creating a pocket along that cross-bar to catch water. I'd try a good soapy canvas cleaner and a bristle brush.
Old 03-07-2019, 08:11 PM
Carguy8888's Avatar
I thought it was a wear mark but you might have a good point. I thought I remember trying to use raggtopp cleaner on it but maybe I'll just need to check with a detail guy once the call comes out of hibernation.
Old 03-25-2019, 09:59 PM
bad_408_vert's Avatar
Got the same mark, hoping to hear about your results.
Nyc car too
Old 03-25-2019, 10:13 PM
Carguy8888's Avatar
What I start using the car and figure it out I'll keep you in the loop.
Old 06-13-2019, 08:57 AM
I’m gonna try chemical guys top cleaner on my car and see how it goes.
Old 06-13-2019, 09:18 AM
Carguy8888's Avatar
I think it's a wear mark and no cleaner will help it, maybe some type of dye would work but I'm afraid to try that. Make sure you try a tiny spot first before you have a disaster. I recently saw one with the same mark and I tried raggtopp cleaner from Hartz, a stayfast convertible top manufacturer. Good luck and please post how you make out.
