Turbo guys running Terminator X
What are you using your I/O for? Do you wish you went with the Dominator instead, or is the Terminator X enough? From what I understand, the TermX comes with a 1bar MAP sensor inside the ecu, so adding a 3bar MAP takes an input right off the bat. Is that correct?
No there is a plug in the harness for a gm style map. This is how I’m planning on running I/o on my x.
In
1. flex fuel
2. dome pressure (boost control)
3 .transbrake/2step activation
4. speed
out
1. 2nd fuel pump
2. Boost control (Mac valve)
3. Not used yet
4. Not used yet
In
1. flex fuel
4. speed
out
1. 2nd fuel pump
3. Not used yet
4. Not used yet
jayyyw (10-22-2019)
currently
ins: flex, split off the MAP sensor for "dome", 2 step, trans line pressure
out boost controller
would I go back and get a dominator? probably not, this thing is plenty for a 9 second car and almost perfect price-wise
do I wish I had more I/O's? yeah of course
jayyyw (10-22-2019)
The Terminator is much like the Holley HP. I think it works great and haven't really found a spot where I've really "needed" more I/O. That said I still prefer the Holley HP unit to the Terminator since it's not as limited in other aspects.
I can trigger the fan, shift light, boost control, two step, water pump, etc off those I/O. You can configure safeties like boost cuts in the software itself without using an I/O, but you can setup a coolant pressure sensor on those inputs for further data.
Things like fuel/oil pressure, MAP, fuel pump, IAT, etc are already on the harness so they don't count towards the optional I/O. Some of the Holley screens now can accept I/O as well further expanding your options.
jayyyw (10-22-2019)
Something that intrigued me was the ability of the dominator to run low impedance injectors. Low impedance injectors are way cheaper. Just another thought to throw in the mix.
jayyyw (10-22-2019)
Good info so far.
Can the HP run DBW?
Can the HP run DBW?
Wait until a pedal or throttle body dies, or throttle hangs for no apparent reason. ***** terrible in a big power car and Ive seen the Holleys have errors in multiple cars. I think a cable is actually smoother and more in tune with what my foot is actually doing to the pedal. I just hate any sort of “translation” in what I want, hence why I like manual transmissions as well.
Inputs:
1. VSS
2. Dome pressure sensor (3.5 bar)
Outputs:
1. Fans
2. Second fuel pump
3. Boost control "fill" solenoid
4. Boost control "vent" solenoid
Using a small air compressor and a pressure regulator dialed to ~60 psi as an air source for the WG dome, 3 psi wastegate spring.
Terminator X Max, manual transmission, drive-by-wire, 370ci Gen III engine at a little under a bar of boost on pump gas. Using the VSS to run a hacky boost-by-gear solution I cobbled together using a custom table.
1. VSS
Outputs:
1. Fans
2. Second fuel pump
yeah pretty much just winged some numbers into the PID from matt happel and its within 1-2 psi of target boost
and it gets better...it lets you pick the top whatever % of your TPS and modulate boost against that percent window so you don't have to get all the way out of it if you spin (this is a very hard muscle memory to break btw)
it's pretty **** for a grand really.
caveat emptor though, the wiring harnesses are assembled by blind people
Plans are
Outputs
1:Fans
2:Fans
3:Mac valve for boost control
4:Mac valve for boost control
Inputs:
1:Trans Brake (for 2step, staging timing modifiers)
2ome pressure
3:VSS
4:might use for crossover pressure readings or maybe to monitor coolant system pressure. Not sure yet
If you ran a dump valve on the tranny for spooling you would need to use one of the outputs for that. At that point tho you better just buy the HP or dominator.
Outputs
1:Fans
2:Fans
Inputs:
2ome pressure
3:VSS
Plans are
Outputs
1:Fans
2:Fans
Inputs:
2ome pressure
3:VSS
Outputs
1:Fans
2:Fans
Inputs:
2ome pressure
3:VSS
thanks,
The HP doesn't have any more I/O then the Terminator X, it has other nice options but limited in that regard.
Some run two if running CO2 or compressed air boost control. Honestly I don't see a real need for it until you are going really fast, plenty of 8 second cars with a single solenoid.
Kinda the same with fans, you can trigger both with the same output.
Plans are
Outputs
1:Fans
2:Fans
Inputs:
2ome pressure
3:VSS
Outputs
1:Fans
2:Fans
Inputs:
2ome pressure
3:VSS
