F150 8.8 rear end into 4th gen f-body
The explorer 8.8 measures about 59” and the 10-bolt about 64.5” so there is a good difference in width hence most people get it widened. But.... I had an 85’ f150 8.8 kicking around and decided to take the backing plates off and measure it ... about 64.5” exactly the same as the 10-bolt, and has 31 spline axles and lsd. The pumpkin looks to be about in the same position as the one on the 10-bolt so I don’t think driveshaft angle would be a problem, Only thing is it has drum brakes. So I took the brake brackets (or wtv they are called) off the explorer 8.8 and they fit bolt on onto the f150 8.8.
my question is why dont people use these diffs? Is there something I’m not understanding here?
visually they look like they are exactly the same width (I measured and they are):
Disc brake brackets on f150 diff:
Inside the explorer 8.8:
But his stuff is holding serious power.
but here's an old post as well
https://ls1tech.com/forums/gears-axl...8-8-build.html
sorry for the lack of precision looks to be between 2-3 inch difference not more.
I'm really curious how this pans out. Ive been wanting a new rear end for the car but dont have the fab skills to do a full cut and weld rebuild, so something a little less involved would be awesome.
. I cut the brackets off my 10-bolt with a plasma cutter, but decided to change routes after doing this because prepping the brackets from the 10-bolt to go onto my 8.8 would have been too time consuming. I decided to buy brackets from racecraft instead. They are heavy-duty 3/16 steel, and are made to already have lower holes to relocate the control arms much lower, replacing the need to add relocation brackets. They are made for 3-1/4 inch tubes, which is the right size for the f150 8.8 (explorer has smaller tubes, 2.8 inch i believe).
Here's the link for the brackets i will be using: https://www.racecraft.com/housing-br...kit-p-706.html
I got my TIG welder setup, and after spending a couple hours at the welding shop talking to some experienced welders, made my first attempt at welding what i beleive to be cast iron (center housing) to steel tubes, it turned out alright. Used lots of preheat, left the torch heating while i made several little passes all around as to not warp anything, then i made a bigger pass over the little one. The result looks ot be pretty solid.
I will be starting the Hiltsy mount tonight, will post updates.
Are you keeping the stock diff in there? I think thats where I'm having my biggest issue on building an 8.8 - Car should be in the 800-1000 range, and was going to slap an S-trac in there..but then that ruins the budget side of it and makes it nearly as much as a 9inch.
Also with the axels - every place I look seems to show that you need to change out the housing ends when buying axels? What am i doing wrong in my searches?
As for the diff, at this point, i think the most budget friendly and solid option would be a spool. I've been researching this option and many people seem to not mind it on the street at all. As for the axles that seems weird as you can get your axles custom made, and most aftermarket axles on summit say ``direct fit`` but im not sure. Could always reuse the stocks till they break or maybe get the stocks cryo-treated? This is supposed to solidify metal quite a bit, i got it done to some of my trans parts.
More to follow on the hiltsy kit as my kit is missing a part, which hiltsy will send me ASAP. His customer service is excellent!!
Check this beefy biatch out, 32-spline cryo-treated mainshaft should be good for 1100ish hp.
https://www.summitracing.com/search/...spline%20axles
And another reason it'd still be better to use an 8.8 over a 9 inch is weight, and how much power it robs to turn it, so...
Plus shipping and duties would cost a fortune for me, is another reason im not ordering an assembled rearend.
Sorry it's been a while, pretty busy on other stuff. I mocked up the Hiltsy mount last night, seems to fit very well. The only parts that don't fit as well on an f150 8.8 are the two little tabs that go over and under the driver side rib, and the vertical tab on the driver's side as well. I had to grind the two little tabs to get them tucked in a little more, and the vertical tab does not have the holes in the right spot for the f150, but i will be welding it instead of bolting so i don't really care. Overall hardly any modification to get it to fit!
