Anyone running All Pro retro LS7 heads?
Old 08-20-2022, 08:08 AM
Gripenfelter's Avatar
LS1Tech 20 Year Member
Default Anyone running All Pro retro LS7 heads?
These are not LSW. They are retro LS7 heads by All Pro.
SPECS Intake port: 267cc & up
Exhaust port: 85cc & up
Chamber volume: 70cc
Intake valve diam.: 2.205 - 2.250
Exhaust valve diam.: 1.580 - 1.615
Valve length: 5.140 & up
408-440ci engines º Yields 400cfm @ .675 lift on intake & 255 cfm exhaust = HUGE power gains º
Compatible with popular 4 bolt & 6 bolt per cylinder blocks º
Accepts std. size LS7 valves, rocker arms, covers, int. manifolds & headers º
Ideal for hydraulic roller cams & 1.325 dia. valve spring kits º
Supreme driveability on the street º
Direct swap for LS7 or LS3 using LS7 manifold
Borowski sees 800 hp on an engine dyno with these heads.
Wondering if anyone here is running them.
Old 08-20-2022, 09:57 AM
Corona's Avatar
Good cylinder head. The reference of Borowski is BS.
All Pro can make 800 depending on port size used and engine combination.
DualQuadDave (08-20-2022)
Old 08-20-2022, 10:35 AM
Old 08-20-2022, 01:55 PM
Tuskyz28's Avatar
That car belongs to a member on board here. Screen name Full-Force....
Gripenfelter (08-20-2022)
Old 08-20-2022, 04:20 PM
Floorman279's Avatar
LS1Tech 10 Year
fwiw, i was dead certain i was goona go with all pro for my most recent build. i called bob up, and got a price. i said well i should call at least 1 more place, that place had a brodix offering as well as all pro options. he said all pros really arent worth the extra money unless you are boosting and can take advantage of the thicker head of the all pro. we were talking almost 1100 dollar difference through this vendor for the all pro offering vs the brodix offering. when i contacted bob and repeated this, he got pretty nasty on me and basically refused to offer any services for me after this. i ended up going with a completely different head porter.
after i made this choice, my tuner said that he has seen the all pros have coolant leaks numerous times that couldnt be fixed easily, and my builder said all pros are decent but they really are an old design and brodix is an up to date head with so many options and from a cost standpoint makes no sense to choose a different head.
G Atsma (08-20-2022)
Old 08-20-2022, 09:24 PM
Corona's Avatar
your paying for the thicker casting, but brodix offers a thick casting in the BS series cheaper.
Richard @ WCCH has more up to date programming. I asked Bob about his All Pro -2 & the as cast cost was crazy... down right... kinda pissed me off. Like $1500 each as cast..
ftw CID or Brodix BS.
The difference is the Material above the runners Brodix BS has a 5.4 length valve Same as Mast or the Non retro All Pro ls7. CID are 5.8 inches and F710' are 5.6's.
Old 08-20-2022, 10:23 PM
I think WCCH uses LSW heads. These are the newer retro LS7 heads that just came out recently.
Old 08-21-2022, 02:02 AM
Corona's Avatar
Richard has updated the Ls7 head to a 290 cc runner.
The LSW is the Same All Pro casting with a 5.4 valve. LsW LS7 heads are All Pro heads nothing New but a updated cnc program. Retro heads utilize standard ls7 valve lengths at around 5.2 inches
http://www.proheads.com/WCCH_All_Pro%20-1.html
Retro LS7 data isn't listed.
But pricing is listed Retro and Ls7-1
Old 08-21-2022, 03:43 AM
Got it.
Ok so this being an NA setup, in your opinion, what would be the best head to go with? CID? Brodix? Mamo 265? or All Pro?
Old 08-21-2022, 05:52 AM
Corona's Avatar
Got it.
In castings itself
CID is #1
All Pro #2
Brodix #3
TFS #4
Best Bang for the Buck in casting is Brodix Big Spring series....
Key is who does the Cnc work. Also what size is the head in terms of CSA/MCSA or CC of the runners.
👉 To match the given rpm and size of the Combination. A healthy 427 going to 7500 requires a certain size head.
My thing with any porter is this, if a better head is given to, theres no excuse on why a cheaper inferior head is better. Btw the Brodix BS casting is cheaper than all listed and Thick. $1600 for the pair as cast. Pick your own porter. If they've got a cnc program your done around $2800 to $3k and a Custom built head made specifically for your combination and the head still has room to grow. 302cc + if needed.
The following 2 users liked this post by Corona:
G Atsma (08-21-2022), Gripenfelter (08-21-2022)
Old 08-21-2022, 10:47 AM
LS1Tech 10 Year
Got it.
first time around i went with mamo, this time around i wanted something different, just didnt want to na builds with the same head. so went with as cast big spring brodix done by a porter. i didnt like how bob at all pro came up with the "you get what you pay for" line after i asked him to compare all pro to brodix. wasnt like i was asking about a assembled heads for 3000. i would hate to know what he would have said if i compared CID to all pro.
most the porters out there who dont have a "shop casting" seem to offer a brodix porter casting. i think they are the flavor right now because they addressed most of the issues of a stock head and most importantly, the porter casting is cheap so theres money for the porters to make. I dont think they are cast in USA tho if thats important, but im 99% certain all pro and Cid is.
Old 08-21-2022, 04:08 PM
DualQuadDave's Avatar
LS1Tech 10 Year
Brodix is all cast in the USA. They have their own foundry, I believe. The Brodix are the bang for the buck winners, all day. CID is arguably best overall. All the big name porters have a CID base causing with their port on it. Greg Good, BES, MBE all have CID specific port combo's that rock.
The following 2 users liked this post by DualQuadDave:
Corona (08-21-2022), Gripenfelter (08-21-2022)
Old 08-21-2022, 04:41 PM
Corona's Avatar
Greg Good, BES, MBE, etc all have Brodix specific port combos also.
get the BR7 BS it'll be thicker than the typical BR7. Example of Greg Good and Brodix. Shaft mounted rockers required with the BS series.
https://horsepower-research.com/prod...eads-assembled
DualQuadDave (08-22-2022)
Old 08-21-2022, 07:03 PM
Fishmasterdan's Avatar
If your looking for the best look at BES newest ls7 head NA supposedly near 440 cfm. Unfortunately not in my budget.
I went with brodix ls7 br bs for big solid rooler springs.
Old 08-21-2022, 10:28 PM
LS1Tech 10 Year
i went with BES, def on the higher end cost wise for a BR7 but i think it will work out......wont know for another 8 months or so tho. the only thing is they have one cnc program, so if you are going turbo or n/a you get the same head. using a 2.2 intake and 1.625 exh i think is better for a turbo, where an n/a build might do a touch better with larger than a 2.2 intake and decrease the exh to fit.....again im just speculating but either way i know it should perform great either way......i might be reading into valve sizes here too much but figured id mention it.
The following 2 users liked this post by Floorman279:
Corona (08-22-2022), DualQuadDave (08-22-2022)
Old 08-21-2022, 11:01 PM
I'm definitely staying NA. Looking for a max effort type head but should be tame enough to be able to drive on the street as well. 4.125 bore 427.
Old 08-21-2022, 11:23 PM
Tuskyz28's Avatar
The TFS 245 heads you running now are no joke... Roddy Coleman car (427ci/TF245) gets respect no matter it goes....
Old 08-22-2022, 12:01 AM
Yeah they are super torquey on the bottom end. Great for the track.
Local guys all roll race though.
Old 08-22-2022, 05:02 AM
Corona's Avatar
That head was Worked over pretty good by GG...
Same porter Different heads...
btw Fishmasterdan there's nothing new From BES and a Ls7 head.
Double06 (08-22-2022), Gripenfelter (08-22-2022)
Old 08-22-2022, 07:23 AM
Received 3,700 Likes on 2,250 Posts
LS1Tech 10 Year
In castings itself
CID is #1
All Pro #2
Brodix #3
TFS #4
How are you ranking a bare casting? Material? Deck thickness? Spring pocket? Valve angle? I ask this because before the CNC port and chamber work and hand finish is applied, you only have a big heavy chunk of aluminum.
Quick Reply: Anyone running All Pro retro LS7 heads?
