Notices
Freshly rebuilt LSA engine with Molnar internals, ported LSA heads zero miles!
Engine - Complete
  • Engine - Complete -  - Used - -1 to 2024  All Models - San Ramon, CA 94583, United States
gnx7 is offline
    $2,600
  • Location San Ramon, CA, 94583, USA
  • Condition Used
Fresh 4.070" LSA block with Molnar 3.622" forged crank (58x and 6 bolt rear flexplate style), Molnar PWR ADR rods with ARP2000 bolts, CP race pistons with .230" wall wrist pins, machined, balanced and assembled, file fit rings for boost assembled by Joe's Engine shop in Concord, CA (used to run NHRA... they have built a ton of LS engines for myself and buddies including an 1800rwhp R35 GTR engine that dominated in our area without issues aside from transmission hahaha). Includes ARP2000 head studs  ($450) that were used for the torque plate/honing/boring. I kept the stock stroke so that it wouldn't lose the piston squirters when using a stroker crank.  Once again this is for a 6 bolt flywheel/pressure plate not the 8 bolt style LSA.
$8K
1 set of freshly done LSA heads CnC ported by Gromm Racing, performance valve job, LS3 intake valves, LY6 Inconnel exhaust valves, new guides, BTR .660" lift spring kit $2600
If you buy both and pay shipping I will crate this up for free in a very secure pallet/box.  If you need cam and other related parts I can source those also.
To complete this you need all timing parts, front/rear covers, cam/lifters/pushrods, head gaskets, valve covers, oil pan, oil pump.  I believe I have a set of LS3 rocker arms and will check this week.  I have a set of used valve covers you can have and a used front cover.  I can assist with getting the other parts if you want BTR stuff.
Old 12-26-2023, 02:46 PM
gnx7's Avatar
Christmas bump to the top!
Old 01-02-2024, 12:06 PM
gnx7's Avatar
2024 bump it up
Old 01-07-2024, 03:33 PM
gnx7's Avatar
To the top!
Buy both for $10K, I'll build the crate for free... you pay for shipping.
Old 01-13-2024, 04:07 PM
gnx7's Avatar
to the top
Old 01-21-2024, 05:22 PM
gnx7's Avatar
Flow chart for the heads! Top is LSA and bottom is the LS7 (other set of heads I'm selling)
File Type: pdf
Old 01-25-2024, 11:04 AM
f8lvenom's Avatar
What’s the compression with those heads?
Old 01-28-2024, 03:58 PM
gnx7's Avatar
Not sure why I didn't mention it... but with a .051" LS9 style head gasket the LSA engine it would be 10:1 compression which is great for e85 and boost.
Old 02-03-2024, 02:29 PM
gnx7's Avatar
weekend bump
Old 02-12-2024, 01:42 PM
gnx7's Avatar
to the top!
Old 02-19-2024, 12:55 PM
gnx7's Avatar
to the top
Old 02-27-2024, 11:30 AM
gnx7's Avatar
to the top!
Old 03-11-2024, 11:04 AM
gnx7's Avatar
complete LSA built longblock for 1000rwhp+ still here
Old 03-13-2024, 09:24 PM
xdanny510x's Avatar
Im like 30 mins from concord ..hayward to be exact.. im looking for a shop to either rebuild my 408 or take a look at it if i can send it ..is the shop you mentioned good? Reasonably priced?
Old 03-18-2024, 06:34 PM
gnx7's Avatar
I use Joe's Engine shop in Concord. This is the BUSY time of year so don't expect it back anytime soon hahaha. I'll PM you.
Old 04-10-2024, 12:03 PM
gnx7's Avatar
to the top! $10K for both (its a fresh built shortblock with the heads boxed up freshly machined also) So you can choose what cam/lifters etc you want to run. I can help supply those as well.
Old 05-04-2024, 03:24 PM
gnx7's Avatar
May the fourth be with you! To the top
Old 05-12-2024, 02:42 PM
gnx7's Avatar
You know your Mom would love an LSA engine with a flower bouquet on top
Old 05-25-2024, 03:32 PM
gnx7's Avatar
to the top fully built LSA longblock begging for a healthy turbo or blower setup to finish it.
Old 06-17-2024, 09:32 AM
gnx7's Avatar
summer bump
