Thoughts on this turbo?
Can anyone guess if it spools better and/or makes more power than a billet VS Next Gen 7875? Also does anybody know if its physically bigger? I don't have space for a bigger diameter cold side unless I change some stuff up.
https://turbo4less.com/product/vsr-8...ons-available/
Oops, its updated.
Looks like a copy of the Garrett 7975g with journal bearings. "Pulsar" turbos have a 7875 with a "compact" compressor cover. If I could get that on this turbo I think I'm in business. I want a journal bearing for sure.
Pulsar version with compact cover:
https://amtuned.com/products/pulsar-...hp-rating-1450
I'm 99% sure those come out of the same factory in China...
Here's a variant with a smaller compressor side, 7375g. Thought of Rel3rd and wondered if this is the ultimate LS tire fryer on the street. Again, I would want a journal bearing if I could find such a beast
https://www.pulsarturbo.com/product/...ompact-hp1200/
I believe its this guy (Pulsar and others are probably all very similar)
https://turbo4less.com/product/7689-...ptions-copy-2/
I went ahead and ordered the turbo in my original post. Seems to check all the boxes for me. From what I can gather its pretty much exactly the same on the turbine side as the VS Next Gen and Gen 3 7875 turbos. Compressor side should flow the same or a little more and spool faster. The biggest selling point to me is its vbanded together. Its usually easier to deal with installing and removing in my experience. Anyhow, I will report back after its installed. Will be a few weeks maybe a month.
That’s a fair amount bigger.
https://www.pulsarturbo.com/product/psr-7782g-hp1500/
i bet they would sell you the t51r mod’d cover for it just email them. They have great support
you need the t51r mod cover. Do you have the compact version?
I actually discovered that if you back out the speed sensor port plug it makes the compressor loud just like a t51r. Still isn’t like my 7875 with the 10 blade turbine. It sounded like a jet out of boost.
I just know it can help with coking issues. If they are getting away with it thats cool. My understanding is journal bearing works just fine in our typical LS applications. Not going to matter much on the street. So I wanted to KISS.
