Looking for engine bay pictures for 2000 Ws6
Hey Guys. Putting a 2000 WS6 back together and a shop had the engine out and butchered the reassembly. The brake lines and heat shields that run along side the drivers side of the engine along the frame rail are all messed up. Does anyone have a picture of the engine bay with this area in stock form so I can figure out what all is missing.
Thanks!
Thanks!
Basically, there's a plastic clip/bracket that holds the fuel lines and brake lines. It attaches with a bolt that has a stud on the end, and the heat shield goes over that. The heat shield is attached with a few more of those bolt/studs down the frame rail and ends beneath the firewall. There's a dip in the shield that lines up with the steering shaft. The lines coming off the ABS block will more or less self locate into the clips on the plastic bracket, just install the plastic bracket and you'll see. My factory plastic bracket wouldn't hold the lines close enough to the frame rail for the clearance I needed, so I made one out of aluminum. I no longer have factory fuel lines, which made it easier. I can take a pic, but mine is not stock. I have a few pics of a stock '98 SS in that area, but it doesn't show the actual heat shield, only the lines leaving the ABS block and going down into the area where the shield is located.
Your hood latch cable goes over the top of your strut tower next to where the fender bolts on, there's supposed to be a small push in cable guide there. You can run your cable out the side where your fuse box is located, then around the front to the latch.
