Is this a superhawk hood?
Old 08-20-2024 | 05:15 PM
cammednnbs's Avatar
Default Is this a superhawk hood?
The hood was on the car when I bought and I really like it but I'm not positive that it's a superhawk hood. I'm pretty sure it's not one of Roger's superhawk hoods cause the quality is not the best. Can anyone tell what hood this is by the pics?
Old 08-20-2024 | 06:00 PM
wannafbody's Avatar
Looks like a Superhawk to me.
Nathan C (08-20-2024)
Old 08-20-2024 | 08:26 PM
cammednnbs's Avatar
How do you tell if it's a Roger superhawk or an ebay special?
Old 08-22-2024 | 12:52 PM
cammednnbs's Avatar
Can anyone tell if this superhawk hood was made by roger?
Old 08-24-2024 | 06:29 PM
cammednnbs's Avatar
I guess no one can tell if this is a legit Roger's superhawk hood or a knockoff?
Old 08-27-2024 | 07:00 PM
Daydream's Avatar
I think it is a knockoff. The US Exotics Superhawk hoods made by Roger had mesh grilles molded into the nostril and heat extractor openings.
Old 08-28-2024 | 04:44 PM
Kev98Ta's Avatar
10 Year Member20 Year Member
I have one one of Roger's hoods on my car, and yours does look real close, but i'm not 100% sure... I attached a photo of the underside of my hood, the molding seems a bit different along the sides, near the front, by the head lights.
Old 08-28-2024 | 05:10 PM
cammednnbs's Avatar
Kev98ta were your heat extractor functional?
Also was your ram air cut out clean? Mine was cutout sloppy but I cleaned it up with an air saw.
Old 08-28-2024 | 05:17 PM
cammednnbs's Avatar
It does look like a real one. Mine is cut out for the aerolatches I think that's why it looks different.
Old 08-28-2024 | 10:01 PM
Daydream's Avatar
Hey cammednnbs,
I have a Superhawk hood too, but it was damaged in an accident. The heat extractors are functional. The cutouts for the heat extractors are on the vertical support near the hood strut mounts. The ram air cutout was a clean rectangle.
Here is a link with good photos of the areas you're asking about: Superhawk hood
Old 08-29-2024 | 01:18 PM
cammednnbs's Avatar
Thanks for the link was wanting to make the extractors functional but wasn't sure where to cut. It looks like it's a knockoff but it is actually pretty well made and fits well. One more question I stupidly opened hood when I had car up on my quickjacks and put a chip in nose of the hood. How would I fix a chip in a fiberglass hood?
Old 08-29-2024 | 02:58 PM
Daydream's Avatar
I haven't done much bodywork, so take my advice with a grain of salt. If it's just that little bit of damage in the photo, you might be able to use glazing & spot putty.
Old 08-29-2024 | 03:06 PM
cammednnbs's Avatar
That's what I was thinking but wasn't sure if spot putty would work on fiberglass or if I needed to reglass that spot. Yes it's just that little knick in the pic.
Old 08-29-2024 | 03:54 PM
Daydream's Avatar
I know Bondo spot & glazing putty can be used on fiberglass. I haven't looked into any other brands. If I was planning on repainting the hood, I would give that a try.
If you aren't planning on repainting the hood, you might be able to fill that damage with touch up paint and clear coat. Its not ideal, but it will save you lots of time and money.
Old 08-29-2024 | 06:35 PM
cammednnbs's Avatar
I'm probably going ro repaint entire car and prep for paint over the winter.
Quick Reply: Is this a superhawk hood?
