Ls1 with msd 6014 how to create fuel delivery without carb
Does your engine have an ECM operating the ignition and injectors?
Or are you trying to run the injectors off an ignition module?
I am running ignition off a module for spark but I have to use ecu for everything else just not sure it will work since module uses cam and crank and temp I wanna know what reads the injection is it separately censored
the MSD 6014 is just an ignition box for running the LS with a carburetor.. It can not fire the injectors as well and work
post #6 you claim to have both the ignition box and an ECU. so what are you working on and what are you trying to do?
G Atsma (09-11-2024)
I doubt he really has any clue about how any of this works.
