factory alarm problems
Old 05-12-2005, 01:57 AM
808z28's Avatar
Default factory alarm problems
My alarm is going crazy, disconnected the horn, disconnected the shock sensor, disabled the shock sensor in the program mode. Now the light just blinks. Does any body know where the alarm box is located? Can I just disconnect it?
Tony Earnest (03-31-2021)
Old 05-25-2005, 01:18 AM
808z28's Avatar
i guess no one have no solution for this problem
Old 05-25-2005, 07:05 AM
Ungrounded Moderator
WhiteBird00's Avatar
No, the factory alarm is controlled by the BCM and you can't just disconnect it.
Old 05-25-2005, 09:05 AM
prince xizor's Avatar
Is there a way to permently disarm the alarm? I just got a viper 690 installed and occasionally when my passenger locks the door from the inside and I arm the viper, there is no problems. But when I disarm the viper and open the door the factory alarm goes off. Is there a way to permanatly disarm the factory?
Old 05-25-2005, 09:25 AM
Here is the information on programming from your owner's manual:
PROGRAMMING THE FACTORY ALARM
ENTERING PROGRAMMING MODE
To program features, the car must be in programming mode.
1) Turn key to RUN position.
2) Turn key to OFF position.
3) Remove the RADIO fuse in the main fuse panel.
4) Turn the key to ACC
You should hear a chime to verify that the system is in the programming mode.
1 chime means you can program Exit Lighting, Delayed Illumination, Last Door Closed Locking and Lock Out.
2 chimes means your car is equipped with Content Theft-Deterrent System so you can also program Remote Keyless Entry Verification, Arming Method, Arming Verification, Driver's Door Delay and Shock Sensor Enable.
EXIT LIGHTING & ILLUMINATION
With exit lighting, your interior lamps will come on for up to 25 sec. when the key is removed.
With Delay Illumination, your interior lamps will come on and stay on for up to 25 sec. when entering the car and up to 5 sec. when leaving the car.
To change the factory setting...
1) Turn the courtesy lamps on by turning the instrument panel brightness control **** all the way up.
2) Count the number of chimes you hear. The number of chimes tells you which mode you are in.
3) Turn the courtesy lamp switch off.
4) Turn the switch on and off until you hear the number of chimes that correspond to the mode you want to be in.
MODE 1 Both Off.
MODE 2 Delayed Illumination Only.
MODE 3 Exit Lighting Only.
MODE 4 Both On.
LAST DOOR LOCKING & LOCKOUT PREVENTION
To change the setting...
1) Press the LOCK switch on the door.
3) Press the LOCK switch on the door until you hear the number of chimes for the mode you want to be in.
MODE 1 Both Off (Door will lock and unlock when you press the door lock switch)
MODE 2 Lockout Prevention Only (If you leave your keys in the ign. and leave thru the driver's door, you won't be able to lock the doors with the power door lock switch.)
MODE 3 Last Door Closed Only. (If the power door lock switch is used to lock the car while any door is open, you will hear 3 chimes. The doors will not lock until all the doors are closed.)
MODE 4 Both On. (This combines Mode 2 and 3.)
REMOTE KEYLESS ENTRY VERIFICATION
To change this setting...
1) Press the UNLOCK button on the remote transmitter.
2) Count the number of chimes you hear. This tells you which mode you're in.
3) Press the UNLOCK button on the remote until you hear the number of chimes that correspond to the mode you want.
MODE 1 All Off. (The head lights will not flash and the horn will not sound)
MODE 2 Horn and Lamps/Lamps (Your horn will sound and your parking lights will flash when you press the LOCK button on the transmitter. Only the parking lamps will flash when you press UNLOCK)
MODE 3 Horn and Lamps (Your horn will sound and the parking lamps will flash every time you press LOCK or UNLOCK)
MODE 4 Lamps (The parking lamps will flash when you press LOCK or UNLOCK)
MODE 5 Lamps/Horn and Lamps (Lamps will flash on the first press on LOCK, your lamps will flash and the horn will sound on the second press on LOCK and the lamps will flash any time you press UNLOCK)
THEFT-DETERRENT VERIFICATION
1) Press the LOCK button on the remote.
3) Press the LOCK button on the remote until you hear the number of chimes you want.
MODE 1 All Off (No horn chirp or lamp flash)
MODE 2 Horn and Lamps (Your lamps will flash and the horn will chirp twice)
MODE 3 Horn and Lamps/Lamps (If you use the remote to arm the system, your lamps will flash and the horn will chirp twice to verify the system is armed. If it only chirps once, the hatch is open or unlatched. If you use either the power door lock switch or passive arming, only the lamps will flash for verification)
THEFT DETERRENT ARMING METHOD
1) Press the UNLOCK switch on the door.
3) Press the UNLOCK switch on the door until you are in the mode you want.
MODE 1 Alarm System Off (System will not arm)
MODE 2 Remote Keyless Entry Transmitter Lock (When you lock the doors using the remote, the system will arm itself)
MODE 3 Remote Keyless Entry Transmitter/Power Door Lock Switch (If you use the remote or the popwer door lock switch to lock the doors, the system will arm)
MODE 4 Passive Arming and Remote Keyless Entry Transmitter/Power Door Lock Switch Arming (The system will arm itself after all doors are closed plus arming per MODE 3)
DRIVER'S DOOR ALARM DELAY AND SHOCK SENSOR ENABLE
1) Turn the parking lamps on and off
2) Count the chimes
3) Turn the parking lamps on and off until you hear the number of chimes you wany
MODE 1 Zero Delay and Sensor Disabled (The alarm will sound immediately if the driver's door is opened with your key and the shock sensor will be disabled)
MODE 2 8 Second Delay and Shock Sensor Disabled (The alarm will sound 8 seconds after the driver's door is opened with your key and the shock sensor will be disabled)
MODE 3 Zero Delay and Shock Sensor Enabled (The alarm will sound immediately after the driver's door is opened with your key and the shock sensor will be active)
MODE 4 8 Second Delay and Shock Sensor Enabled (The alarm will sound 8 seconds after the driver's door is opened with your key and the shock sensor will be active)
LEAVING PROGRAM MODE
When programming is done, turn the ignition to OFF and replace the RADIO fuse.
You want to set the Theft Deterrent Arming Method to mode 1 (off) to disable the factory alarm.
Old 05-30-2005, 12:45 AM
808z28's Avatar
thanks for the info
Old 03-05-2006, 11:55 AM
TwoFast's Avatar
thank you for the helpful info..
Old 10-01-2008, 11:15 AM
Mid
Mid's Avatar
This stupid owner's manual instructions didn't help me at all...what chime am I supposed to hear???? I tried going into programming mode but no chime, except for the door being open. HELP me please
Old 10-01-2008, 11:32 AM
Try closing the door after removing the RADIO fuse but before turning the key to the accessory position.
Old 10-02-2008, 08:29 AM
Mid
Mid's Avatar
Ok ok I got it this time...I'm an asshat
Thanks for the info WhiteBird
Old 01-12-2017, 07:43 PM
Derick Morgan's Avatar
Default My car sucks
hello. I have a 98 trans am. Every time I open the door I have about 20 seconds to put the key in the ignition or the alarm goes off... how do I stop this problem!!?
Old 01-13-2017, 06:40 AM
The only way to prevent that but still have a working alarm is to unlock using the remote key fob. If you don't have a fob, you can get one from Amazon or Ebay and program it to match the car. Otherwise, you'll have to disable the alarm using the instructions above. That's because the alarm system is not connected to the door lock cylinder so when the door is opened without disarming the alarm with the fob (even when unlocked with the key), it assumes the car is being broken into.
Old 05-25-2017, 06:40 AM
Guillaume Malaquin's Avatar
Hi everyone,
I recently import in France a new BCM (UPL, 691) to remplace my BAS, 681 and add Keyless entry. So I have it now and it work perfectly. Except I don't have the "Panic button" working and the turns signals don't flash when I lock or unlock the car (with the horn signal too).
So, I guess the flashing and horn signal come with the alarm? Or it can be programmed? Because I try : On (Or run with the engine started?), Off, Take off the fuse, ACC and nothing happened to me..
Thanks !
Old 05-25-2017, 01:50 PM
The entry verification options (lights flash and horn honks) are only programmable with the optional alarm system. With basic keyless entry you can only program Exit Lighting, Delayed Illumination, Last Door Closed Locking and Lockout Prevention.
1) Turn key to RUN position (do not start car).
4) Turn the key to ACC position.
MODE 1 Both Off.
MODE 4 Both On.
MODE 3 Remote Keyless Entry Transmitter/Power Door Lock Switch (If you use the remote or the power door lock switch to lock the doors, the system will arm)
2) Count the chimes
Old 05-25-2017, 03:46 PM
Here we go
Old 07-10-2017, 04:35 PM
Here we go
No clue?
Old 07-10-2017, 05:20 PM
Already answered above...
So yes, the flashing parking lights and horn chirp come only with the alarm system (Content Theft-Deterrent System).
Old 09-20-2017, 01:37 PM
Hi,
So.. I did it in the wrong way. I retry today, and I have 2 chimes, so content Theft-Deterrent System. BUT, I programming in the right way everything, and I don't have my turn signals flashing or Horn chirp anyway... An Idea?
Old 09-20-2017, 04:05 PM
The Theft Deterrent Verification will only work if you actually arm the alarm system which means you first have to set Theft Deterrent Arming Method to something other than mode 1.
The Remote Keyless Entry Verification should work even if the alarm is not armed. Most people prefer mode 5 so that the horn only sounds if you press the remote's lock button twice (only the lights flash otherwise). Also, the remote has to be matched to the car... if your remote locks and unlocks the doors then it is already matched. After you hear the two chimes indicating that your have entered programming mode and you have the optional alarm system, press the unlock button on your remote. The system will chime 1-5 times to tell you what mode is set. Press the unlock button on the remote and count the chimes each time until you get to the number of chimes that correspond to the mode you want to set. Then turn the ignition off and replace the RADIO fuse to exit programming mode.
Trust me, it will work as long as you have the alarm option in your car and you follow the instructions exactly. If it doesn't work, go back and do it again. There have been plenty of members on here who have complained that it doesn't work and then come back a few days later saying it worked after they slowed down and did all the steps exactly as listed.
Old 09-20-2017, 04:47 PM
The only thing can be an issue, it's that : the shock sensor, the speaker under the hood and one of 2 interior sensor was removed. Probably a previous owner. So I guess it won't work?
If I remember right, the Theft Deterrent Arming is on the Mode 4
Quick Reply: factory alarm problems
