Sneak peek at the LS1 plate.
Old 09-12-2005, 02:47 PM
Nitro Dave's Nitrous Outlet's Avatar
Default Sneak peek at the LS1 plate.
This is a multi-port discharge plate.This gives you a larger cover area for your nitrous stream which will eliminate distribution problems seen in most ls1/Lt1 based plate applications.
These are introductry prices.So pricing may change in the future.
The COMPLETE SYSTEM will come complete with a 10lb bottle with high flow 45 valve,Microswitch,wiring harness and relay,main feed line,stainless steal quick release bottle brackets,300 Hp lifetime warrenty solenoids,Nitrous Plate,oil ring gasket,throttle linkage spacer,jetting from 35-150,hoses,bolts,and fittings. All this for 650.00
CONVERSION KIT- Comes with the plate,Oil ring gasket,Throttle linkage spacer,Bolts,Fittings and jets 225.00
These should be ready to ship before the end of this month(September).
We are now taking orders.These are not on the web site at this time so you will need to call in at 1-866-648-7637
Dave
Dave
Old 09-12-2005, 03:16 PM
Ouija's Avatar
First of all, that's a nice looking piece.
If this is a secret, fine, but I'm just curious how the machining is done to get the little holes in the plate where the N2o obviously comes out into the intake.
The 12 little holes. Are they drilled at a slight angle, or is there some custom tool that y'all have that drills them straight? Like a belt driven drill bit or something?
I'm doubting that the metal is formed around a mold, so I'm jsut curious.
Old 09-12-2005, 03:21 PM
BMN
BMN's Avatar
Think I just found Stage II for the ol' test mule. Does it have special noids or can you use the set that comes with a 20920 kit?
Old 09-12-2005, 03:22 PM
MrDude_1's Avatar
i wonder that myself.
Old 09-12-2005, 03:34 PM
PAGregSS's Avatar
Not exactly what I anticipated but interesting.
Old 09-12-2005, 03:38 PM
XTrooper's Avatar
Dave,
It looks sweet!
I hope you'll have a version available where you can just screw the nitrous and fuel lines from your existing system on as in the DTE and NOS versions.
Old 09-12-2005, 03:50 PM
PAGregSS's Avatar
That's exactly the style I was hoping for. I wanted fittings so you could just route hoses to the plate and have the solenoids mounted elsewhere. Unless that may be what the top plate is. The pictures look like two different plates. Hopefully that is the case.
Old 09-12-2005, 03:51 PM
theblur98ss's Avatar
Are these going to be available in differant sizes for say the 90mm fast intake?
Old 09-12-2005, 04:10 PM
Elite_Hot_Rod's Avatar
Dave do you know if NX intends to offer a plate for a carb style manifold?
Old 09-12-2005, 04:23 PM
Closed ex-Sponsor Account
NXRICKY's Avatar
That intake uses a 4150 flange then I have a plate for it... Anyone want to send there intake into me I would be more than happy to flow a plate on their intake.
Ricky
Old 09-12-2005, 04:29 PM
Shipping charges would kill me but I might be willing to take a vacation day from work and drive it up.
Ricky
Old 09-12-2005, 04:34 PM
OK here are the answers.
1. This plate canb use any manafacures solenoids.
2.The plates are built with custom tooling.I would rather leave it at that.
3.You can mount some solenoids directly to the plate or remote mount the solenoids.
4.Yes these will be available in all sizes.
5.We also have plates desighned for the LT1,LS1 and LS2
We have you covered.
Dave
Old 09-12-2005, 04:37 PM
Brandon Boomhauer's Avatar
shipping a manifold is cheaper than $3/gal gas....
oh and Dave, it looks badass, amazing machine work too.
Old 09-12-2005, 04:51 PM
NXRICKY's Avatar
You have one I will send a call tag for it, just to let all memeber know what the plate is and what it looks like(spray pattern) on that intake..
You game.?
Ricky
Old 09-12-2005, 05:03 PM
SPANKY LS1's Avatar
Ricky
How thick is the 4150 plate?
Old 09-12-2005, 05:05 PM
NXRICKY's Avatar
3/4 for billet, If I had to build a custom one could be a bit thicker... Ever intake has a different look coming out of the mold.
If that is to thick I could just put spray bars inside your intake.
Ricky
Old 09-12-2005, 07:20 PM
silverZ98's Avatar
hey dave can i take my single shark nozzel kit i got from you and make it work with this plate?
Old 09-12-2005, 08:35 PM
Phoenix 5.7's Avatar
any idea of prices for it? i was lookin at the NOS plate, but this looks even better. and yall will have 1 that works for the 90mm correct?
Old 09-12-2005, 10:05 PM
gollum's Avatar
The discharge holes look very interesting (better atomization of nitrous/fuel). I am sure the final product will look and match verywell with NX brand systems.
Old 09-13-2005, 05:41 AM
XTrooper's Avatar
If I understand Dave's reply correctly, the answer is yes. I have the same single Shark nozzle setup as you do. I believe all we have to do is attach the nitrous and fuel lines (along with the appropriate jets) to the plate. This eliminates the nozzle itself as the plate handles the dispersion duties.
