Stock L92 Head Flow Data
I just finished flow testing a new stock L92 head. All I can says is…….WOW! What a nice part.
I’d like to publicly thank StreetnStrip for the opportunity to test this head.
The test head has casting number 5364. Here’s the tale of the tape……..
4.030” test bore
Lift ___.100 _.150_.200_.250_.300 _.350 _.400 _.450 _.500 _.550 _.600 _.650_.700_.750
#1 Int. 74.9 109.4 154.4 193.5 225.3 252.8 274.6 292.7 308.8 321.0 328.7 326.6 310.0 316.6
#1 Exh. 63.6 97.9 126.1 148.7 162.3 178.6 189.6 197.6 205.5 210.7 214.6 217.8 221.2 223.5
The intake was tested with a radius plate and the exhaust was tested with a 2 ˝” stub pipe.
4.155” test bore
#1 Int. 73.8 108.7 153.2 192.6 225.2 253.6 277.0 296.7 313.0 326.0 335.8 326.9 327.3 317.1
#1 Exh.61.1 97.9 125.7 148.1 162.0 179.5 191.8 200.1 205.9 213.3 218.4 220.9 221.9 223.2
Exhaust port tested without pipe (4.155” bore).
#1 Exh.63.1 94.7 121.1 140.6 156.9 165.8 176.1 182.8 187.9 191.4 193.7 195.6 197.6 199.5
Valve dimensions:
Intake = 2.160” X 4.870” X .314”(8mm)
Exhaust = 1.590” X 4.920” X .314”(8mm)
Seat/throat diameters:
Intake = 1.870”
Exhaust = 1.355”
Volumes:
Intake runner = 260.6cc
Exhaust runner = 90.0cc
Chamber = 69.8cc
A few observations………. These heads have the best seat/port lineup for an as cast GM head that I’ve seen. Their casting precision is VERY good. The fit and finish of the valves are very nice as well. The intake port is large, especially the area above the short turn radius. The intake cross section starts at 3.1sq/in at the intake flange and grows to almost 3.7sq/in forward of the guide boss!
I’m a bit disappointed with the exhaust port flow. IMO it needs to be at least 25 peak cfm better. I’m sure the engineers at GM know what they’re objective was and they were satisfied with the final product but I think for hot rodding especially blown applications, the exhaust port needs to be improved. Looks like head porters will have something to do after all………
I understand that there is a company working on a 4bbl carb style intake, but I’ll leave the intake manifold subject for another thread.
Happy hot rodding.
Richard
4.030” test bore
4.155” test bore
Valve dimensions:
Intake = 1.870”
Exhaust = 1.355”
Volumes:
Chamber = 69.8cc
Happy hot rodding.
Richard
At the moment I have too many projects on the front burner. I'll consider a CNC program when more support parts (ie. intake manifolds and valves) become available.
The flow rolled over gently between .600" and .650" There was no definitive flow drop at a particular lift.
Richard
Richard
Closed ex-Sponsor Account
Richard
Richard
Damn, man. Just install a 1.60" exhaust valve, blend the throat, and polish the port. Then clean up the intake port with a 120gt flap wheel and you are done!!!! Killer information!!!!
Richard,
Like I said before, the L92 and LS7 heads are all anyone is ever going to need for 370 cid on up. This is going to be great for you to clean them up, maybe even do full turnkey assemblies. There is no doubt it is going to put real pressure on the aftermarket heads considering the price point.
Brent
The Warhawk heads will be for the big number f/i crowd.
Brent
Originally Posted by ace68
OH MY GOD, and they are what around 200-300 each brand new.
Nate
Originally Posted by Nate_Taufer
160 a pop from GMPartsdirect.com. They are bare though. You'd need ls7 rockers, rocker stands, valves, springs, retainers, seals, and keepers but that stuff is probably only another 900 bucks.
Nate
Nate
Originally Posted by BLKWS6
i priced out a full set yesterday using the L92 valvetrain....less than 600 total for the set.
Stock springs are good to what lift? Wouldn't think them to be that high. Maybe .550" max if you're lucky.
Also would probably want stainless valves in high hp applications (what most people would be using these for).
Nate
