tps voltage @ idle and wot?
MuhThugga (10-21-2023)
The limit=4.71, so stop at 4.68 or so. But you might not even get the pedal to open it to 4.68, mine bump stop is grinded down to 4.68 but the pedal only allows it to open to 4.58 when i mash it.
That's what she said...
Originally Posted by JDP
is there even any difference to doing the bump stop mod. mine is at 4.45 right now
i might do it when i take my throttle body off to port it.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Some people's are so shitty, that the car doesn't pick up 100% TPS and doesn't put the car in power-enrichment mode.
How are you guys measuring this? My car is throwing the tps code I want to know if I need anew one or if something else is wrong? Not sure about this stuff would like to learn how to check this stuff out. Do I need to hook my car up to a scanner or tunning equipment to know the voltages. And what's the bump stop mod? Grinding some off the thorottle blade stop? Any help would be appreciated thanks.
Pretty sure the purple wire at the connector is the +. Then just ground the other side of your volt meter and turn your key on while activating the butterfly by hand. You will need to puncture or tap the wire bc the sensor must be plugged in to obtain the reading.
[QUOTE=GOaT Cheese;5322386]Around .5 at idle (.48-.53) and aroung 4.90 at WOT (4.80-4.95)[/Q
So what? What's it to you? It's new to me. So back off. Smfh...jeez....ctfd already
