Pictures of the GMPP LSX Block
Old 10-30-2006, 08:26 AM
LS1Tech Sponsor
Robin L's Avatar
Lightbulb Pictures of the GMPP LSX Block
For you that cannot make the trip to the SEMA show I have ben authorized to share some pictures before them show opens on Tuesday. I have seen the block up close and it's beautiful.
Press Release handed out at SEMA: https://ls1tech.com/misc/LSXblock.jpg
Enjoy
Robin Lawrence
Attached Thumbnails Pictures of the GMPP LSX Block-dscf4030small.jpg   Pictures of the GMPP LSX Block-dscf4031small.jpg   Pictures of the GMPP LSX Block-dscf4035small.jpg   Pictures of the GMPP LSX Block-dscf4050small.jpg   Pictures of the GMPP LSX Block-dscf4063small.jpg
Old 10-30-2006, 08:35 AM
Karlo's Avatar
Thanks Robin
Old 10-30-2006, 08:41 AM
Richard@WCCH's Avatar
Thanks for the pics! Any idea what the weight of these blocks are?
Richard
Old 10-30-2006, 08:43 AM
Billiumss's Avatar
Very Nice, Love the color! Price?
I know you probably shared the specs on this in other threads, care to share them again in this thread for others to enjoy.
Old 10-30-2006, 08:48 AM
LS1Tech Sponsor
Robin L's Avatar
Guys
There is a data sheet that will be passd out at SEMA. I am trying to post the PDF file when I get my hands on it. I will be leaving for the Airport in a few minutes. As son as I can get the file (and near a computer) I will post that info and answer any questions that I can.
Right now I am outa here to catch a plane.
I wanted to post them before I left. Thanks for understanding.
Robin
Old 10-30-2006, 08:50 AM
Billiumss's Avatar
Thumbs up
Originally Posted by Robin L
Guys
Robin
Thanks, can't wait!
Have a safe flight!
Bill
Old 10-30-2006, 09:01 AM
Z06PSI's Avatar
More headbolts on this one too!!!!!!!
Old 10-30-2006, 09:02 AM
Karlo's Avatar
**************Originally Posted by DB Z28************
100% CNC Block Cast iron (280 kpa tensile)
True proirity oiling
Siamese cylinder bores
6 head bolts per cylinder
Standard 4.400 bore spacing Standerd deck height (9.700 tall deck to Follow)
Increase deck thickness
LS7 6 bolt Doweled in place Billet Main caps
Max 4.500" Stroke (tall deck only) Capable of a 364 to 500+ cid Tall deck for large displacement
Wet and dry sump capabitly
Deep Skirted Head bolt Holes
Orange power coat
Maintains all OEM LS family exterior mounting features
Accepts all Gen III & LS Heads ,cranks Cams ,ect.
Includes Unique new cam retainer,rear cover and lifter retainers and OEM cam bearings
Front Motor Plate mounting holes added
Added material above cam bearings for added strength
Approximate Finish weight 225 lbs
9.26 semi finished deck height (Standard deck height)
3.990 bore ready for honing,maximun 4.250bore @ .200 Minimum wall thickness.
6 bolt LSX bolt pattern
11mm standerd bolts 8mm exterior /interior bolts
Can be machined for 1/2 in bolts or studs
All 5 cam bores for standard small OD bearings P/N 12453169
can also be machined to 60mm roller bearings
Added material around standerd .842 lifter bore also can be machined for large lifters and/ or 1.050 bronze bushings
O-ringed screw in soft plugs
Accommodates any LS small block oil pan and oil pump, standard LS wet sump systems and LS7 dry sump systems fit.
Extermal oil pump feed @ rear of block
Front oil line can be plugged and external oil pump /aftermarket dry sump system can be used.
Belt cam drive can be accommodated.
7th tranmission bolt hole added per early sbc
Main web bay to bay breathing holes for increased HP
Access windows for cylinder head stud access (intake side)
Extra Breathing pockets added near starter for better windage
Thats it real nice sweet Coming March 2007
Old 10-30-2006, 10:16 AM
BigBronco's Avatar
Thank you Robin!
Old 10-30-2006, 11:44 AM
ONEBADWS6's Avatar
Thanks Uncle Robin!! Now we just need GM to start a class for all us LSx guys
Sharpe's Avatar
Wow! The cylinders in the new LSX blcok are big enough to fit my ***** down in them!!! That's big!!!
Thanks for your coverage Robin!
Old 10-30-2006, 12:02 PM
Bill's 02 Z-28 SS's Avatar
Are sure you where not looking at the 9/16 threaded hole????
Old 10-30-2006, 12:07 PM
Sharpe's Avatar
Hey, it might be thin, but it's short!
Old 10-30-2006, 12:13 PM
red90cobra's Avatar
wonder what the price is gonna be I'd better start saving
Old 10-30-2006, 12:18 PM
Bandit28's Avatar
nice pics cant wait for one!
Old 10-30-2006, 12:56 PM
NemeSS's Avatar
cant wait, for one
Old 10-30-2006, 01:19 PM
gollum's Avatar
Good things come for those who wait/waited. LIKE ME!!!
Old 10-30-2006, 03:04 PM
1CAMWNDR's Avatar
So, does this mean GM will start making a 6 bolt performance cylinder head .
Old 10-30-2006, 03:17 PM
LS1Tech Co-Founder
Nine Ball's Avatar
Thanks for posting the pics Robin, I'll be at SEMA starting Wed, maybe I'll run into you there.
Tony
Old 10-30-2006, 03:30 PM
chuntington101's Avatar
wonder what this thing is going to do to the warhawk block???
looks good.
Chris.
Quick Reply: Pictures of the GMPP LSX Block
