SLP L92 Cylinder Head/Manifold Package
Check out the new SLP L92 Package for all you cable driven throttle body guys. All the info you need is in the link. Including mutiple dyno tests, photos and videos.
http://www.slponline.com/coming_soon_12293.asp
Hank
Hank
Originally Posted by tlaselva
Exactly what I was waiting for.
Thanks SLP!
What about us E T/B guy's?
Thanks SLP!
http://www.slponline.com/coming_soon_12292.asp
P/N 12292 = Drive By Wire
P/N 12293 = Cable Drive
Hank
The cam used in the 402 testing was the SLP 51014 cam.
236/236 .590/.590 112LSA +0
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Originally Posted by Bill's 02 Z-28 SS
nice package but why only 8 roller rockers?
thanks
Bill
thanks
Bill
You are to re-use your stock exhaust rockers. Only the intake valve on the L92 head is offset, which needs the 8 offset L92 intake rockers.
edit: The L92 Intake rockers with this kit are 1.7 ratio. The same ratio as your stock LS1/LS2 intake rocker.
Hank
Now I'm getting very exicted! I spoke with Hank a few weeks ago when he was working out this combo.
I'm mating a SLP ZL-402 with a Patrick G. cam recommendation (from Thunder Racing). I can't wait to see what the numbers look like.
With Kevin's 402 making gobs of torque (and not to shabby in the horsepower department either) I think the combo of L92 heads (Duals springs/ shaved .030 with the exhaust and bowls cleaned up) and L76 intakes will suit my needs.
All I'm waiting for is the cam. It's like being a little kid at christmas!!
Bob K.
Bob K.
Originally Posted by 02sierraz71_5.3
Maybe Im missing something so the extra 800 bucks is for 918 springs and 8 rocker arms?
800 bucks over what? The kit comes with everything needed. Manifold, Heads Decked and Assembled, Injector Adapters, Rockers Arms and pedestals, and throttle cable bracket.
edit: Do not try and add a set of stock L92 heads and Manifold together and compare to this kit. It is extremely competitively priced. Add it up, do not forget the decking and assembly. We also use the correct/different spring seats and new valve seals to make 1.800 install height. Using the stock L92 spring seats with valve seals (one piece) will give a compressed install height (unless you mill down the head under each spring seat). We are not just slapping springs and retainers on these heads, that does not work.
Hank
Hank
Hank
I was just wondering about what your getting past the 1500 setup that GM sells. Im sure the kit is very competitive, Ill admit Im ignorant when it comes to the new stuff. Just looking for the value, no offense meant.
The $1500 setup from GM will be a head with a chamber of 72cc and valve springs only good to .525 lift. No injector adapters or throttle cable bracket. Both are needed for an LS1 harness cable driven vehicle. Since you would only be able to use a .525 lift cam your power levels will be very low. As well your compression will be significantly less assuming the same pistons used, also resulting in less power. We have not completed any testing with such a cam (.525 lift) back to back. BUT, we have completed testing of the stock 72cc chamber vs the SLP chamber with an SLP cam on our engine dyno. Results were great for us.
I will post results of that testing tom PM for you.No offense taken.
Hank
Originally Posted by KUL FIR CHICK N
Does the throttle cable bracket allow the throttle by wire body to be converted to cable operation? I'm unclear on this one.
Ryan
Ryan
No, the bracket will be used for a 90mm cable throttle body. A FAST throttle body for example. Since there are a few 90mm throttle bodies out there we will let you choose yours, the reason it is not included in the kit. We used the FAST 90 on all of our tests. You can sell the electronic throttle body that comes with the manifold on ebay.
edit:
There is no provision on the L76 manifold to mount your current LS1 throttle cable bracket. That is why we are providing one for you. It allows both mounting of cruise control and throttle cable in the correct location.
Hank
Hank
Hank
have yall put reseach into custom cams for 402/408 L92 setups yet?
Originally Posted by Forteen3GT
no custom cams??? just a 236/236 .590/.590 112.....
Yes we have, we are coming out with those results very soon. We achived over 525 flywheel ft-lbs with shorty headers stock catted GM y-pipe and a SLP powerflo exhaust with the SLP L92 package. All with a 800 RPM idle.
We are very excited about releasing this new cam as well. You will see a similar post to this one in the next 2 weeks as we are finishing all the numbers with a full "f-body 402 setup"edit: the setup above is for a GM Silverado/Sierra 402 street pacakge. With Longtubes, High Flow CATS, F-Body induction (lid/bellows) the power number above sky rockets, but you have to wait for those results
as we want to post a detailed page like the one for the L92 heads.Thanks
Hank
Originally Posted by White_Hawk
Does that bracket have a seperate part number? I already got the rest of the stuff.
-Geoff
-Geoff
i already have a L76 intake... need a bracket to bolt up a fast 90 throttle body..... can you hook me up???
you guys where alittle late with this... I would have purchased the entire kit from you and likely saved a bit of coin if I had known.
what he said.....
We can hook you guys up with the bracket. I will post the P/N and pricing soon.
Yes we are late, BUT we are the only ones with this much testing and detail. We wanted to make sure we provided the best cost highest performing L92 head package we could. We are the first to offer the complete package though.
Hank
