GM parts: Misc. LSx/LT1 gaskets, lots of GM stuff!!
Old Mar 30, 2007 | 07:20 PM
lt4malibu's Avatar
Default GM parts: Misc. LSx/LT1 gaskets, lots of GM stuff!!
spent the day cleaning out my shed and sorting all the stuff i've accumulated, everything is NEW unless otherwise noted. all this needs to go so here's the list:
LSx/LT1 stuff:
-NIB LT1 power steering pump GM# 88985330 - $50 SOLD
-NIB LT1 power steering resivoir hose (connects resivoir to pump) GM# 26025371 - $5 SOLD
-LT1 waterpump gaskets (i have 3 sets) - $2each
-LT1 throttle body gasket (i have 3) - $2each
-L98 tuned port upper plenum gasket kit GM# 12508751
-LT1 coil wire GM# 12096466 - $3
-LT1 coolant bypass pipe (used - bolts to the back of each head and connects at throttle body) - $5
-LT1 oil pump drive (used) - $5 SOLD
-LT4 roller lifters(set of 16 - used w/6000 miles) - $20 SOLD
-LSx exhaust manifold gasket (set) GM# 12558573 - $5 SOLD
-LSx valve cover gaskets (set) GM# 12560696 - $5 SOLD
-LS1 valley cover GM# 12561107 - $10 SOLD
-LSx/LT1 style oil fill cap GM# 12573337(these are just the regular 5w30 style) - $2 each
-Street & Performance LT1 fuel rail adapters(lt1 fuel rails included) - $50
- '96 LT1 PCM, unit was new from GM, then sent out to PCMforless and programmed for: headers, VATS/AIR/EGR/SKIPSHIFT delete, lt4 hotcam, ported heads, 373 gears, also has LT4 knock module - $200
other gm parts:
-BOSE amp (used -for '00up extended cab p/u) GM#15054671 -$50
-LSx C/K waterpump GM#12567795 (has literally 30minutes of run-time on it) - $30
-S/T & C/K ps pump(used) FITS 96-99 4.3 AND 5.0/5.7 ENIGINES GM#88963505 - $20
-HVAC control head for C/K utility GM#16247335 - $50
-88-99 C/K brake pedal pad(i have 3) GM#15080812 - $5each
-trailblazer 4.2 I6 ignition coils-USED(i have 3) GM#12568062 - $10each
-4.3 valve cover gaskets for W and X engines (i have 2 sets) GM#10201397 - $5each
-3.1/3.4 intake gasket for newer style engine that has 6 bolts on the upper plenum (kit- comes with lower manifold gaskets and upper plenum gaskets) GM#89017279 - $25
-3.1/3.4 valve cover gaskets(1set) GM#10154775 - $5
-2.2 valve cover gasket 98up(i have 3) GM#24575855 - $5each
-center bolt style SBC valve cover gaskets (5sets) GM#10046089 - $10each
-01up impala passenger mirror(power) - $25
-02up trailblazer driver headlamp assembly - $50
-S/T truck drivers side mirrors, power/heated (i have 2) - $30each
-S/T truck passengers side morrors, power/heated (i have 2) - $30
-C/K 88-95 drivers mirror, non-power - $10
-C/k 88-95 passengers mirror, non-power - $10
Old Mar 30, 2007 | 09:02 PM
ND4SPD _SS's Avatar
will this work on a 2000 LS1?
Old Mar 30, 2007 | 09:14 PM
lt4malibu's Avatar
i dont think so, the upper radiator hose outlet comes up instead of out and will be in the way of the throttle body
Old Mar 31, 2007 | 08:06 AM
lt4malibu's Avatar
bump...
Old Mar 31, 2007 | 08:20 AM
Red97Z's Avatar
Can I get pics of the LT1 power steering pump and hose? Blackpixi7@hotmail.com Also how far are you from central nj, trenton?
Old Mar 31, 2007 | 09:58 AM
lt4malibu's Avatar
ill get pics later this afternoon, id say im about 1.5-2 hours from trenton.
Old Apr 1, 2007 | 07:26 PM
lt4malibu's Avatar
PM's replied
Email sent Red97Z
Old Apr 2, 2007 | 09:37 PM
lt4malibu's Avatar
Ttt...
Old Apr 3, 2007 | 05:53 PM
lt4malibu's Avatar
...ttt
Old Apr 3, 2007 | 06:20 PM
maybe2fast's Avatar
the lifters? are they any different from LT1 lifters?
Old Apr 3, 2007 | 06:44 PM
lt4malibu's Avatar
they were part of the GM LT$ hotcam kit, i think they are heavier duty???
Old Apr 4, 2007 | 10:09 PM
lt4malibu's Avatar
bump...
Old Apr 4, 2007 | 10:20 PM
pat35's Avatar
pm sent
Old Apr 4, 2007 | 10:39 PM
'89ChevyMadneSS's Avatar
Originally Posted by lt4malibu
-S/T & C/K ps pump(used) GM#88963505 - $20
is this truck power steering pump in good condition? have the bracket youd sell too?? pm me this info and a price shipped to 65689 plz. (i stay on the truck side usually and when i do come over here the forum moves too fast ) so the pm is appreciated and i have cash in hand
Old Apr 5, 2007 | 07:11 AM
pat35's Avatar
pm sent about lifters
Old Apr 5, 2007 | 09:48 AM
lt4malibu's Avatar
PMs sent.
Old Apr 5, 2007 | 02:09 PM
lt4malibu's Avatar
all PM's replied
Old Apr 5, 2007 | 09:06 PM
pat35's Avatar
pmsent
Old Apr 6, 2007 | 05:44 PM
lt4malibu's Avatar
PM's replied, whatevers left goes on ebay sunday...
Old Apr 6, 2007 | 06:19 PM
playtoy_18's Avatar
Lol,just curious
Are you a GM tech?I'm a Ford tech and I've got stack's of the same type of stuff laying around.Part's that were replaced for whatever reason though not faulty, and aftermarket stuff on used,trade-in and auction PDI's.
