2001 Z28 FS ,True 800rwhp daily driver
Putting this up for a friend.Built the car 2 years ago and he's been driving ever since without 1 problem.
Maroon Z28
built 408ci iron block
234 Cam
AFR 225 heads
Evans water pump
Edelbroke carb intake,intake elbows 90
75lb injectors
Nasty fuel cell with dual Weldon pumps
Ford 9" locker rear with 3.50 gears
Built M6 by 6 speed inc
SPEC dual disk clutch ,Mcleod bell housing
K-member and tubular suspension
T-88 turbo with truck manifold kit. TIAL wastegate 8-14lbs
2 TIAL blow offs
4" intercooler
3.5" downpipe to cutout ,to 3" catback
Thats the basics right now.Easilly over $50k into this and drives like stock.
Looking for $28k
here are some pics. Not many recent one's but can get them shortly. Car ran 10.2 (or .4) at 140mph on 10" ET streets(smoking the whole track)
Dyno graph of old Cam,need to update new Cam which made more.
This is run 100% 93 octain only.No mix
Maroon Z28
234 Cam
AFR 225 heads
Evans water pump
75lb injectors
2 TIAL blow offs
4" intercooler
Looking for $28k
Theres about 35k original on the car but only 7k on entire fuel/motor/rear/driveline. I will get some updated pics of setup, the piping is all redone and painted black and silver and its cleaned up a bit. These pics are older.
Car also has dennys billet end driveshaft (1500hp model)
Full wilwood breaks 6 piston front, 4 piston rear zicn slotted/cross drilled
corbeau seats
wolfe 4130 chromoly 6 point cage with 5 point rca harnesses
entire suspension is tubular with adj front and lower a arms and k member
strange 10 way dbl adj shocks front and back
wolfe tubular chromoly sub frames
custom built/offset two piece hoop gt intro rims 17x9, 17x11 with nitto 315 dr in rear and 275 nitto extremes up front
slp line lock
electronic cutout
and so much more, i have 99% of the reciepts on this car and how much money is really into it. Any questions please feel free to pm me or slowhawk, either one of us can answer them further
pic of car with rims and what not as it sits
corbeau seats
slp line lock
electronic cutout
LS1TECH Sponsor
TTT
I have personally seen and rode in this BEAST! It's fast, and the street manners of this car are amazing! The car has been very well taken care of and Don (slowhawk) has done a kickass job creating it!
LS1TECH Sponsor
its a sad day to see this car go
i have seen/rode/driven this car personally and drives mint. car is extremely fast.
all hes done to it since it was finished 2yrs ago was wash wax and oil changes
whoever gets it will have one beatiful fun to drive ride
Damn Mike!!!!!!! Any projects in the future?
BTW, sweet car, insanely fast, and well built. Mike has taken me for a ride a few times in this beast. Its fast enough that the person in the passenger seat will be stepping on the imaginary break pedal in fear for their life once you hit warp speed.
I'm sure this car will scare the crap out of most people here. With it's stock drivability thats says it will no way make power.Then you blow past a big litter bike on the highway with ease.Only problem the car likes to skim the front wheels in 4th gear which you have to let off the gas to change lanes
Skimming the tires in 4th. I wish I had that problem Awesome car.
I've seen it too and quite frankly would like to have it. I'm moving into a new house in Maine mid-June and will be buying a car within the following month. I can't see this still being available, but keep me in mind if it doesn't sell before. I was wanting a Zo6 or Viper, but I just might consider buying my third Camaro in a row.
Fred
Fred
