Performance parts F/S
Old Apr 23, 2008 | 12:05 PM
aNuBiS's Avatar
Talking Performance parts F/S - Reasonable offers on remaining
Now fielding reasonable offers on all remaining red lettered items.
Patriot 2.5 LS6 "style" heads(2.055/1.6 valves) 59cc w/ AFR #8019 springs 1100$SOLD
Super7 locks & titanium retainers, good to over .650" of lift.
They have not been milled.
They have been independantly CNC ported at another shop after being purchased.
These were then sent to AFR and professionally flow benched last spring. If interested I can provide the flow numbers. The upgrades were done in March 2007, barely a year ago. Very nice set of heads. [/I]
Comp custom camshaft 239/244 .654/.614 109.4* LSA
Had this spec'd out by PatrickG, very nice cam, I put flycuts in my pistons to run this camshaft and recommend this be done or be used with aftermarket dished pistons. I still have the Cam Pro Plus Lift Report of all the cam specs, I paid 389$ plus shipping for this in March, plus the 30$ to have it spec'd out for me. I would like to get 275$ for this. ( I also have the fly cutting tools I used to cut the reliefs in my pistons for this cam if interested)
ARP 12pt head stud kit, one of the smaller studs is minorly stretched because when I installed them last year, I forgot to change the torque setting on the wrench after tighening the larger studs. A replacement can be ordered easily from ARP, I actually never bothered and it worked fine, but its an option and theyre still great studs.
SOLD
Racetronix injectors
Delphi Part #17113798
Manufacture Specifications (using gasoline):
Static Flow Rate @ 43.5PSI / 300kPa : 38 lb/hr +/-5%
Static Flow Rate @ 58.0PSI / 400kPa : 43.9 lb/hr +/-5%
Coil Resistance: 12.0 Ohms / High Impedance / High-Z (Will work with factory ECM/PCM drivers)
These are racetronix 38# injectors, but at our LS1 fuel pressure they flow 43.9# SOLD
TSP ported LS6 oil pump, had excellent oil pressure at all times SOLD
Rollmaster timming chain 80$
TSP 7.4" hardened pushrods SOLD
LS7 lifters SOLD Again, just bought these in March 2007
I am changing this year to a large cube build in which most of these parts either wont work or arent proper size/spec. I would otherwise keep them and move them over like my other parts. Most of these parts barely have 1000miles on them (if that) As I bought and built this combo last spring, some of the others have approx 4000miles on them. Dont get the car out much with the winters I have hahah. I am pretty firm on the prices as they're retarded as it is.
Old Apr 23, 2008 | 12:28 PM
tnmotown's Avatar
im still kinda a newbie but will those LS7 lifters work in my LS1? also is that $80 shipped? you bought them in march so they are brand new? let me know please im very interested
Old Apr 23, 2008 | 01:25 PM
LS1-Inside's Avatar
Sent PM on Heads!
Thanks,
Dan
Old Apr 24, 2008 | 01:39 AM
SS#2906's Avatar
PM sent on oil pump.
Old Apr 24, 2008 | 07:31 AM
72RATCAMARO's Avatar
interested in heads. price shipped to 37921
Old Apr 24, 2008 | 12:33 PM
RICEETER's Avatar
pm sent
Old Apr 24, 2008 | 05:21 PM
aNuBiS's Avatar
PM's replied and list updated.
Old Apr 24, 2008 | 06:12 PM
blahster's Avatar
those ls7 lifters...you bought them new? how many miles are on them?
Thanks,
Benny
Old Apr 24, 2008 | 06:16 PM
aNuBiS's Avatar
Yes, I bought them new in March 2007, so barely a year old, and I only drove the car until August. Theyve got maybe 1000miles on them.
Old Apr 24, 2008 | 08:12 PM
lsx10's Avatar
interested in heads price shipped to 85737? and what is the difference between ls7 and ls1's?
Old Apr 24, 2008 | 08:34 PM
aNuBiS's Avatar
PM sent, and the ls7 lifters are the factory replacement for ls1 lifters now.
Old Apr 24, 2008 | 10:30 PM
Eric Hawkins's Avatar
So are you saying these are the older patriots with the welded chambers? If so could you PM me a price shipped to 30707.
Old Apr 24, 2008 | 10:31 PM
aNuBiS's Avatar
https://www.patriot-performance.com/...&cat=37&page=1
I believe is what they are, except I have added upgraded AFR #8019 springs, and they have been touched up to flow beyond their advertised lifts, rather than drop off.
Old Apr 24, 2008 | 10:53 PM
Are there any casting numbers anywhere on the heads? Maybe in the rocker area?
Old Apr 24, 2008 | 11:08 PM
aNuBiS's Avatar
I mean, those ARE the heads..lol. Except they have been CNC ported to provide flow beyong 600" and now have AFR #8019 springs.
Old Apr 25, 2008 | 07:36 AM
The part that was confusing me is that you say they are "LS6 style" heads and they have not been milled. Untile about a year ago patriot would weld the chambers on a 317 casting head to get the 59 cc chamber. Now that the Ls6/Ls2 castings are so cheap they just use them and mill them to the 59cc chamber. I need a set of the welded ones so i can mill them down to a 52cc chamber and not risk a super thin deck.
Old Apr 25, 2008 | 11:58 AM
aNuBiS's Avatar
Oh, I didnt realize this, well yes these are the ones with the welded up combustion chmbers. Thats how I was able to stay with stock gometry and have 59cc.
Old Apr 25, 2008 | 08:51 PM
aNuBiS's Avatar
Bump for my cam
Old Apr 27, 2008 | 08:57 PM
aNuBiS's Avatar
heads are sold.
