are my goals to high 5.99 in the 8th
hey guy just finised my turbo setup stock lower end arp 2000 bolts and head bolts, good head gaskets ,ls6 intake, fast 78 tb,42# injectors,67mm turbo,fmic,water meth, th400 thans with a brake ,12 bolt 35 spline 355 gear,weight of car around 3400 with me in it has all suspension mods exp. coilovers, the kit is advertized to make 650hp @ 9psi through an auto a car here with the same kit on 5psi and a slipping 4l60e made 510rwhp so at my weight a hp numbers around 600+ is my goal of a 5.99 8th out of question thanks guys forgot to add have stock ported heads with a comp ratio of 9-9.5 to 1
i think your off a lil cause my buddies mustang weights 3400 and only makes 464hp and is running 6.80 in the 8th so your saying ill only gain a tenth with allmost 200 more hp
well ya our nova is a 10.5 outlaw ran a 7"1 @ 174 all motor in a qurter so im not new to this and my avitar is not for looks also so please dont talk to me like im stupid dude i was figureing 620s maybe sum teens honistly i would like to brake 5s thats all i was asking and if ur car is makin 725 it seems kinda slow for those hp nimber i mean ur times r good but shuld be alot better at those numbers
well ya our nova is a 10.5 outlaw ran a 7"1 @ 174 all motor so im not new to this and my avitar is not for looks also so please dont talk to me like im stupid dude i was figureing 620s maybe sum teens honistly i would like to brake 5s thats all i was asking and if ur car is makin 725 its fukin slow for those hp nimber i mean ur times r good but shuld be alot better at those numbers
My car was making around 700 RWHP on my last time out. The car was hooking good (1.39 60') and the best I ran was a 6.03 @ 114. My car's race weight is right around 3190 right now so I think if everything goes well with yours then you will be looking at 6.50's to 6.70's.
My goal was also a 5.99, I just barely missed it. I barely missed the stock cube nitrous record too (9.32) I went 9.36 @ 145
There is a drag racing calculator that can give you a pretty good idea. It's in the sticky's in the Drag Racing section.
I went 6.055@117 with a 1.38 60 foot on a suboptimal pass (had to pedal it to bring the front end down).....
Car was making like 720RWHP on spray.... I think on a full out pass where I don't have to lift it'll go 5.85-5.95 with the same tune.... my car weighs 3400....
Car also has a 10 pt cage and wheelie bars.
You have the turbo and all that goes with it so that will add weight but you could probably get her down some more I'm sure.
Nothing crazy, removed all the usual stuff like stock seats, ac/heater, center console, bumper supports-blah blah. Car has all the light weight suspension items, drag brakes, draglites, lightweight hood, manual steering rack, manual brake booster etc etc.
i havnt spend any money on weight reduction except for drag lites.. at the track i run skinnies on front and 16 inch alloy camaro rims on back...
ac is gone bumper supports rear seats w/ seat belts cruise control wiper fluid heat shields exhaust is dumped before axle just two speakers in the very front also cut all wires but tail light wires running to back of the car..
from outside the car looks stock (weight wise) except for the rims.. on the inside the only thing you can see are the seats missing.. only noticable things are the A/C and front bumper support (but people usually arent looking at that if the hood is popped anyways)
ya so far all a/c stuff is gone ,front sway bar, bumper support, washer tank, insalation under carpet and all the saets are gone added two of the plastic one up front and relocated battery then from the 4l60 to the th400 i lost 65# then i have tubular k member but i added the 12 bolt and turbo stuff, and water meth so im not sure were ill be sitting
