Single Digit Club Running 9s or quicker? Damn!
7 Second N/A LS powered dragster.
Old 11-11-2013, 09:30 PM
7 Second Club
D. Lee's Avatar
Default 7 Second N/A LS powered dragster.
Wanted to show my time slips and a pic of my LS powered dragster..
Thanks
Dustin Lee
Attached Thumbnails 7 Second N/A LS powered dragster.-ls-dragster.jpg   7 Second N/A LS powered dragster.-ls-time-slips.jpg
Old 11-11-2013, 09:57 PM
19736.o's Avatar
Very nice
Old 11-12-2013, 02:25 AM
LS1rob00's Avatar
Sweet.
I can't imagine what a 1.1 60' would feel like.
Old 11-12-2013, 03:16 PM
98CamZ28's Avatar
Details on setup? Sounds awesome.
Old 11-12-2013, 08:10 PM
1BAD98LS1's Avatar
Deadly consistent! Would make a nice super comp dragster..
Old 11-12-2013, 08:29 PM
Zmg00camaross's Avatar
That .014 light won't cut it lol. Would like to know specs of the engine!! I would sell my car to build a LS dragster
Old 11-12-2013, 11:09 PM
7 Second Club
D. Lee's Avatar
Thanks guys, the dragster is a 1988 Ed Weddle chassis it's my old comp car, the engine is an LS2 aluminum block with LS3 heads on it, it's 364" and is 13.7:1 has a Lunati crank and rods, Wiseco Pistons, Comp Cams Hydraulic Roller, stock rocker arms that have been bushed, Edelbrock Victor Jr. Intake, 850 Quickfuel carb, has an External single stage oil pump, Moroso Vacuum pump, GM front drive distributor set up, has a Mikes Trans power glide with an A-1 7" converter in it.. 4.33 gears and the dragster weighs 1360 lbs. with me in it.. The Headers are a Tri-Y set up that i came up with and had Greg Holman at REF Headers build, it has its own sound above 8000rpm!
I dynoed the engine at Bill Maropulos's shop, it made 520 on torque at 6500 rpm, and made 680 horsepower at 7700 rpm.. I two step it at 5200, shift at 7800, and goes thru the traps at 8100.. I'll post up the dyno sheet tomorrow for ya guys.. First LS I have done, all I can say is what a neat and good running engine!!
I built it just to bracket race, but i might do some super comp racing as well,
when i'm not running Top Dragster with my other SBC combo.. That one goes 6.80's at 194mph.. With a N/A 394" Small Block..
Thanks
DL
Old 11-13-2013, 04:00 PM
1BAD98LS1's Avatar
Thanks
DL
Wow, 6.80's with a N/A small block in top dragster! Damn most of them guys are running 565+ cubic inch big blocks and spraying to get that fast lol
Old 11-15-2013, 10:24 PM
MillsMotorvation's Avatar
That is amazing!!!!!!!
Old 11-21-2013, 08:54 PM
BigEd_72455's Avatar
So where is this DYNO SHEET you said you would put up? Got any pictures of the build up?
Old 11-21-2013, 08:56 PM
I can!! Ping pong with the eyeballs til your brain says to them "WE ARE MOVING DAMMIT!!! PAY ATTENTION!!" and they then face forward again...
Old 11-23-2013, 11:29 AM
7 Second Club
D. Lee's Avatar
Here is a pic of the LS dyno sheet.
Attached Thumbnails 7 Second N/A LS powered dragster.-ls-dyno-sheet.jpg
Old 11-23-2013, 12:07 PM
Dkrug35449's Avatar
im sure that small block is a splayed valve comp eliminator motor to be runnin that fast! maybe a little spray too?
Old 11-24-2013, 11:28 AM
7 Second Club
D. Lee's Avatar
Actually it's a 15 degree Chevy 615X casting with one carb, and no spray.. Makes 932 hp @ 9200 and 630 ft.lbs at 7400.. I can say that it leaves hard with sixty foots between .980's to 1.01 on a 12x33 tire at 1455 lbs.
Here is a pic of the engine.
Attached Thumbnails 7 Second N/A LS powered dragster.-top-dragster-sbc.jpg
Old 11-24-2013, 03:20 PM
the title of the thread says it is LS powered but that engine is typical SBC...
What gives?
Old 11-24-2013, 05:20 PM
7 Second Club
D. Lee's Avatar
What gives?
I run two engine combos one is a standard style small block Chevy the other is the LS the last quote the guys asked about my top dragster setup, which is a standard style SBC, when I run the local summit series brackets I run the LS small block.. I'll post some LS engine pics for ya..
Old 11-24-2013, 07:13 PM
71 chevy's Avatar
hey, looking good.
question: have you ever run it without the hood scoop? how much does it lose without the scoop
Old 11-24-2013, 08:33 PM
7 Second Club
D. Lee's Avatar
Here are a couple pics of the LS Small Block.
Thanks
DL
Attached Thumbnails 7 Second N/A LS powered dragster.-ls-small-block.jpg   7 Second N/A LS powered dragster.-ls3.jpg
Old 11-24-2013, 08:36 PM
7 Second Club
D. Lee's Avatar
Originally Posted by 71 chevy
hey, looking good.
I have not tried running it with out the scoop, but i do know that a well known prostock guy i know told me that what the scoop picks up in power feeding the engine with air, it takes the same power to run thru the air at speed. Hope this helps.
Thanks
DL
Old 11-24-2013, 09:41 PM
1BAD98LS1's Avatar
Are you running NHRA or IHRA top dragster? My uncle runs top sportsman in IHRA mostly PRO AM events and such and usually top dragster follows suit everywhere they run.
Quick Reply: 7 Second N/A LS powered dragster.
