8 second badge request. 8.86@171
Hey guys. Been reworking the setup from changes over the winter, finally made it to the 1/4 mile. Last year 18lbs went 8.53@168 with great prep, this year was a lazy first half with a pickup on the back end running 17lbs in high gear
https://youtu.be/jmoMYCe9x7AU
It sure did pickup on the back half. Supriseingly though I could feel it lay over a bit on the top end. It wanted more boost for sure. After looking at the data, it only made 17psi in high gear.
Thanks guys. Car is getting prepped for two more 1/4 mile events later in august. I'm swapping out the single adjust rear shocks for dual adjust and proper spring, and some much needed new tires. I'll be testing the first of august to get the tires ran in and see where it wants to launch at off the brake. I should be able to report back with some low 8 second runs soon
