Another “would it break 9s” post ! Poor College student edition!
Been at this for 4 years now, the slow process of building a race car while being a full time student, and part time worker! Finally graduated this last semester so I have a little more time to work on the build with my dad, until I begin law school. So enough of the backstory, at $9 an hour this is what I have put together.
2000 s10 Stepside Extreme
Mono Leafs / Caltrac setup
90/10 Calvert front /Moroso Trick Springs
Viking DA rear shocks
Ford 9 inch 370 gear
th400 transbrake
Engine
6.0 /Ls3 head combo (stock bore 6.0)
custom cam from Martin 23x/25x 62x/62x
super victor intake
750 Holley
1 7/8 headers
arp everything
wisco protru dome piston
Stock rods
Looking to spray 200 shot
th400 transbrake
Engine
super victor intake
750 Holley
1 7/8 headers
arp everything
Stock rods
Close combo, 239/247 .624 I/E 10.8:1 6.0/LS3 combo (LY6 basically) 750 Mighty Demon, 1 ⅞ headers, 5000 stall TH350.
@3450# W/ me in it, has been 10.96@121.54...still a few tenths in it....but as is w/ a 150 shot, 9.8-9.9 do-able.
So with your combo, guessing compression, and using a 200 shot....I believe you'll be in the 9's
Made it to FL2K. Got a few passes in, the best pass was 11.90 @118 . I need to find a way to get my 60ft down. I’m consistent around 1.8-1.9 ... I was running MT streets @16psi . I have a 370 gear, Caltracs, da Vikings rear, 90/10 up front with Moroso trick springs. I understand I am super limited since my cam and converter are made for nitrous. Pretty happy with the results, but I want to improve! Any advice?
Took it back to the track Saturday NA. Did one pass and let off. It lifted the front tires a bit leaving at 3800rpms, let off and got back into it. Went 7.52 to the 1/8 ... 1.82
60ft cause I let off.
When I went for a second pass I didn’t leave the line. I had a lowering block on the car and it expanded when I launched causing the rear end to shift up which broke my drive shaft and the drive shaft broke one of my caltracs lmao .
