Need a title change.... Made my 9 sec pass!
Passes were at New England Dragway today.
'00 SS, Eastside Built 383, Hughes powerglide, Edelbrock DP (only spraying one stage for these passes) What else do you want to know?
Pass #1
60': 1.44
330: 3.98
1/8: 6.13 @ 113.87
1000: 8.00
1/4: 9.59 @ 141.33
Pass #2
60': 1.46
330: 4.02
1/8: 6.20 @ 113.16
1000: 8.07
1/4: 9.67 @ 141.00
Pictures of pass #1
Pass #1
60': 1.44
330: 3.98
1/8: 6.13 @ 113.87
1000: 8.00
1/4: 9.59 @ 141.33
Pass #2
60': 1.46
330: 4.02
1/8: 6.20 @ 113.16
1000: 8.07
1/4: 9.67 @ 141.00
Pictures of pass #1
Originally Posted by raymond mckinney
Which car went 8.95? They look alot alike?
It went 8.95 spraying both stages... I was only hitting it with the first stage when I went 9.5 & 9.6
Originally Posted by SlickVert
Awesome and Congrats!
Is your motor a 383 stroker or all bore?
Tell us about your set-up.
Your car is definitely flying.
Bob
Bob
Block:ls6
Heads:afr205
Compression:10.5-1
Pistons:diamond nitrous
Rods:eagle
Crank:lunati 4"
Cam:Eastside custom cam
Intake:fast90
Throttle Body:nick williams90mm
Description of N2O setup:dual stage direct port edelbrock
Trans:hughes powerglide
Converter:hughes
Rear end & Gears:12 bolt spool w/3.73
Engine Management:ls1 edit by ken quantico
Weight:3150 with 200 lb driver
Originally Posted by NRC-Motorsports
how much Hp do you have the 2 stages set up for?
jay
jay
8 second mod
Originally Posted by Nautilus
We only sprayed the first stage.... roughly a 175 shot. The second..... I'm not even sure what jets are in there now we haven't used it yet this year & I'm not sure how it was left from last year... maybe 150? But I don't know
he runs a 28x10.5 et drag. true 10.5 tire, non W
little more seat time, and a little tweeking, and that car will be ripping for tim!
Originally Posted by Beaflag VonRathburg
That car is definetly hauling, but it's kind of sad when you don't even know what's in your own car and you have to rely on others to tell you.
8 second mod
he just got the car, and we are working on it getting it going at tims pace, and he is learning as we go. he is not an avide racer like yourself, he is a rookie, possable rookie of the year
tim, your file is getting biger everyday.
Originally Posted by Noyzee
he just got the car, and i havebeen around it for like 3 years now, and im the one that jetted it.
Now if you'd just show me where the damn spark plugs go, I would be a real pro.... oh yeah... and what the hell is a tranny... I thought they hung out on street corners
8 second mod
