370 Step Inside If Your Running 9s
Just wanted to know is there a 370 running 9s with the same mods as mine and what set up your running. thanks my best with a 100 shot is 10.36
Hey thanks going to try to squeeze 9s out of here adding more juice and I have a standalone. car went its best at 11.1 on motor. Or I WILL JUST BLOW IT UP TRYING
I doubt you'll blow it up before you hit the 9's... If that motor was built right which, judging by the mods in your sig I assume it was, it should handle every bit of a 250 hit.... Those are the exact internals I'm running, except downsized for a 3.905 bore and a stock stroke in an ls1. I'm planning on hitting mine with at least 200, and probably more like 250 with the occasional 300 hit. PILL IT UP!!!!!
