327 to 383 stroker
for the heads i have a set of gmpp 62cc fast burn heads. I would be using a set of 1.6 rockers and a dual plane intake manifold with a 650 demon mechanical secondary carb and an HEI distributer. for a cam I have a edelbrock performer rpm cam with 234/244 duration a 0.50 on a 112 lsa.
Now the question I have is should I go bigger with the cam or run something different all together. I am worried about water reversion since i am running a wet exhaust. I am looking for a decent power increase as my 350 is only rated at 260 horse power. I am looking for a reliable set up that should make some were in the area of 400-440 hp and about the same in torque since that is whats needed in a marine application. Also must run on 87 octane!!!!
Now before you all jump all over me about just rebuilding the current 350 I want to pull it in on piece as a running unit so if i ever have a problem I have a spare engine i can drop in and go.
any suggestion?
What boat? Drive? and what do you do with it most, I've been doing marine stuff for many years so you can PM me if you have any specific questions.....
what i am looking for out of the new motor is to get a honest 60-65 mph out of it. I mostly like to cruise around with the occassional WOT run from time to time.
Here's a link to my 385ci boat engine build..... I love it and would recommend a 383 anyday.
I also have an Alpha Gen 1 its actually an Alpha SS drive. Spin it 6000rpms with no problems.
http://www.youtube.com/watch?v=fyKTq...eature=channel
http://www.youtube.com/watch?v=Ho1XU...eature=related
If I can't get them operational, I am faced with rebuilding or replacing. rebuilding might be better as I can't fit a complete long block through the hatch. If I'm going to go to the time and expense of rebuilding, I want to know more about the feasibilty of converting these to strokers.
The boat weighs about 17,000# and the existing engines are 235 hp on 4bbl carters. Cruising speed is about 12 knots and WOT is about 22. I would like to able to cruise at about 16 and WOT at about 30. If I could get around 340 hp without drama, it would make for very satisfying boat.
Sorry this is not about cars, and it's Gen 1, not an LS1 but GM small blocks rule the waves. I used to own a 2002 Corvette, if that wins me any points.
Thanks
any suggestion?
