how much power from this combo?
2 bolt main 350 bored 30 over, flat top pistons, stock crank and rods, iron vortec heads 062 casting number with a 5 angle valve job, crane energizer 274 hydraulic tappet cam, 1.5 roller rockers, crane valve springs, edelbrock performer vortec intake and 600cfm edelbrock carb. also electric fuel pump. what do you think that'll make?
are there any aftermarket fuel injection systems that arent thousands of dollars? I saw the holley pro jection setup but says it only supports like 275hp and is still about a grand. Would a corvette TPI intake work? AND just in case I decide to blow my budget all to hell, whats the best overall injection system for the money?
I had the same set up in a truck, all the parts you listed. Someone desktop dyno'd it at 310 hp peak (forgot @ what rpm), and over 400 ft lbs from 1800 to 4500.
Not bad for the 4x4 I put it in, but if you want to go quick, it's not the best combination IMO, you need rpm's.
