How will this cam sound?
LSA should be between 110-112 for a choppy idle and 228+ duration at least.
You could advance your cam a little it would help out with the idle you want raise your power band but thats just a band aid you want a different cam. Use that cam get used to the motor break it in and if you decide its not what you want change it. You should make some low end torque alright but if you put a different cam in you will make alot more torque higher up.
Thats a common misconception i feel like alot of ppl misunderstand by thinking a bigger cam makes more hp.... Yes it makes more hp only because the torque curve is moved up and tq is made by the best volumetertic efficiency of the engine. So if you allow it to breath more due to overlap and duration and lift it will increase the rpm at which best fill and combustion takes place.
Since hp is a function of tq and rpm then yes it will be higher as the tq curve shifts up. HP means nothing its just the ability to do work torque is acceleration and feel.
