Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
193k timing chain carnage
Old Feb 16, 2009 | 10:47 PM
bww3588's Avatar
Default 193k timing chain carnage
so my engine in my K5 just quit on me up on the trail the other night. i hit a bump in the trail pretty hard and it just quit. i figured i knocked an electrical component loose, or broke a wire, so i started chasing wires, and testing components to no avail. so i took it to work (GM dealership) and had one of the techs look at it, and he told me when he cranked it, the dist wasent turning. it could either be a timing chain broke, or a broken camshaft.....well
Old Feb 16, 2009 | 10:48 PM
bww3588's Avatar
thats only about half the **** i dug out of the oil pan with a pen magnet. im dropping the pan friday on my day off and cleaning it out...not excited. i was hoping for a simple broken wire i overlooked....
Old Feb 17, 2009 | 12:39 PM
ZONES89RS's Avatar
In-Zane Moderator
That is simply bad ***, how many people can say that happened to them?
Sorry your ride broke though.
Old Feb 17, 2009 | 01:57 PM
96lt1m6's Avatar
man, atleast it is an inexpensive repair.....
Old Feb 17, 2009 | 03:37 PM
bww3588's Avatar
30 bucks total for parts. that includes timing set, coolant, RTV, new oil pan gasket...
i decided im going to pull the cam out while im down there, give me a chance to make sure nothing else got damaged when the chain came apart. i assume it put a ton of stress on the cam when it let loose.
Old Feb 17, 2009 | 03:53 PM
LS1Formulation's Avatar
I had something similar happen, just quit on me with no warning in a 3/4 ton suburban. Had the same issue - distributor wasn't turning when I turned it over. Unfortunately for me, the small end of a connecting rod was laying in the lifter valley. The rod failed and shot THROUGH the cam and into the lifter valley. I have NEVER seen a small block do that. Let's hope yours is just the timing chain.
Old Feb 17, 2009 | 08:14 PM
cnorton's Avatar
Many combinations suffer bent valves when the timing chain breaks. A compression or leak-down test is a good idea after such an event. The heads may need to come off.
Good luck
Old Feb 18, 2009 | 12:01 AM
bww3588's Avatar
yea, a leakdown test is in the plan...
