How hot should the engine be?
Your running W.P. sportsman heads right? (Sig line) Since these are Iron, I would run a 180 t-stat. Iron heads should be cooler, because they don't disapate heat as well as Aluminum heads.
Running a 195 would be fine, but there is not point to it.
I used to have a 160*(the one that went bad) and the angine ran at 190* durin the day and right at 160* at night.
I think the reason why it ran better when hot is maybe due to having the wrong spark plugs. World recommends using Accel 276 plugs but due to lack of funds I used AC delco R45T.
When the engine was @ around 180 it would sputter at the top end and when it got warm it ran perfect all the way up to 6K
Thanks for all the replies BTW
I know I used to always run ac delco acr45ts plugs in my iron heads. when I got my aluminum ones, I disregared the "instructions" which said the use Plug "X".
The acr45ts plugs thread shank was way to short, the electrode was not even close to the bottom of the hole.
May be something to check, Go the a local parts house and compare the 2. See if what they recomend is a longer plug.
If you have a speed shop near, see if they have the same heads in stock. Then ask If you can try different plug in the head, therefore letting you Phyically see how deep they are seating.
Then spend a little bit at whichever parts house your "friends" with, pulling different plugs. If your like me, You know most the people inside by first name. haha
When I built my 383 I physically brought my heads up with me, then tried different plugs until I found the one that worked best. Which turned out to be factory LT1 spark plugs.
