engine wont idle, or stay running
well im not sure how it should be but the back float level registers about 1/4 way on the window(there is 3 horizontal lines its at almost the first one) and the front does not even register unless u shake the truck and then it sloshes a little bit on the window. there is four little screws(2 on each side of each bowl) that i have turned 2 1/2 turns out. there is also two larger screws on top of each bowl with a nut. im not sure how to go about adjusting them but when i try to back the screw out some to i assume allow more fuel and tighten the nut, the nut will not tighten and fuel leaks out.
ya the booster is ok, however it is old. but there was an open port in the intake and i plugged that off and did some carb adjusting, and i got it to idle. but its still weird...sometimes itll start right up, sometimes it wont, but it stays at idle for a min or so now and then kind of sputters off....maybe a fuel problem?
Are you adjusting things by using a tachometer (not the one in the car), or by ear? If by ear, quit doing that, and get a real tach on it.
