Carbed sbc 350 into a 2000 camaro
im puttin a 350 into a camaro and trying to put a parts list together..
ive done alot of reading on here and would just like some guidance from someone that has already done something similar..
so far ive gathered i should get some sort of tubular k-member to make it easier to bolt up,.. is there one that i could get to allow for direct bolt in application of a sbc?
probaly this one? http://www.bmrfabrication.com/K-Members/KM005H.jpg
also will the cowl have to be cut? if so will this be a problem on a daily driver?
also what throttle cable...
everything else is pretty self explanatiory right?
ive already got the motor.. still need to get a tranny tho... probably a th350 unless i should get something else..
any help would greatly be appreciated
thanks in advance
thanks in advance
What is your budget and goals for this car?
Weekend warrior, daily driver nice weather cruiser?
There are a bunch of things you will need depending on how far you want to take this.
You can use the stock throttle cable but most look for a shorter one out of an S-10 I believe. (search to verify that)
Depending on the carb you run you may not have to cut the cowl very much if at all. If you have to cut alot out od the cowl you will lose your wipers. That will impact your DDing.
Check out the thread in my sig for some ideas.
Good luck,
~Jim~
Good luck,
~Jim~
