Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
bbc question
Old Jun 15, 2010 | 10:57 PM
dkcoleman01's Avatar
Cool
Originally Posted by chevelledave
your better off going with a good AMERICAN Head ...AFR .DART, EDELBROCK...they may cost a little more ...but in the long run they will save you money over the CHINESE JUNK...If all you have is a block ...the crank rods and pistons are gonna be the same price wether its a 4" or a 4.250 stroke ...rods are gonna be 6.385 in length ,,with a pin height of 1.270...piston should be readily available in .040 over ...Also do not rule out the GM factory 781 oval port casting if your on a budget ...easily found and will make tons of power right up to 6000 tp 6500 RPM...check Eagle and Scat for a KIT ...you can get them balanced and ready to go ..
ok cool thanks on the heads, ive priced a set of eldebrock heads but =whats the differents in oval and rectangle port heads.
Old Jun 16, 2010 | 12:29 PM
cambirdracing's Avatar
Oval port for low rpm torque, rect port for high rpm h.p.
Old Jun 16, 2010 | 01:07 PM
Cool
ok is it best to go with oval port
Old Jun 16, 2010 | 03:40 PM
supermouse4's Avatar
It all depends on what you will use the BBC for, if the Impala is used mainly on the street and occasional strip use, then get the oval heads. If racing, go with the rectangular heads.
Old Jun 25, 2010 | 02:21 AM
xx_ED_xx's Avatar
oval if you plan on driving it.
Old Jul 12, 2010 | 06:38 PM
slammed68's Avatar
on a budget you could go with some 049, or 781 casting iron heads.... if you have the coin AFR's new oval ports are sweeeeeet.
Old Jul 12, 2010 | 07:59 PM
I have a set of 215 67 year model 396 closed chambers for sale.
