Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
LS1 vs. LQ9
Old Feb 2, 2011 | 04:26 PM
2008ChevySS's Avatar
Default LS1 vs. LQ9
I recently bought a 01 Camaro SS with the LS1 in it. A couple of years ago I bought a 08 Trailblazer SS with a LQ9 in it, but Chevy says that the motor is a LS2. So what is the difference between a LQ9 an a LS2 that is sold in a Corvette?
Old Feb 2, 2011 | 04:53 PM
David21's Avatar
http://lmgtfy.com/?q=difference+between+lq9+and+ls2
Old Feb 2, 2011 | 04:59 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
The biggest difference that you will outright see the easiest would be that the LQ9 is an iron block and the LS2 is an aluminum block.
If you have an iron block it's not stock. It only would have had an LS2 from the factory.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 2, 2011 | 08:22 PM
The Trailblazer SS is stock except for the exhaust. Chevy promoted the Trailblazer SS has having the Corvette (LS2) motor, rated at 395 hp. The motor in it is the LQ9 and not the LS2. Did GM put the LS2 in any other vehicle besides the Corvette?
Old Feb 2, 2011 | 08:47 PM
David21's Avatar
again
http://lmgtfy.com/?q=ls2
Old Feb 3, 2011 | 08:31 AM
It can not be both stock and an LQ9. If it is stock it is an LS2. If it is an LQ9 it is not stock. Yes, they put the LS2 in vehicles other than the Corvette, they put it in the Trailblazer SS.
__________________
Old Feb 3, 2011 | 12:28 PM
xtreme2001's Avatar
you obviously don't know what you bought or don't know much about cars.......the lq9 was an iron block .the trailblazer ss had an aluminum block.
VEHICLE TYPE: front-engine, rear- or 4-wheel-drive, 5-passenger, 5-door wagon
BASE PRICE: $33,600-$39,200
ENGINE TYPE: pushrod 16-valve V-8, aluminum block and heads, port fuel injection
Displacement: 364 cu in, 5967cc
Power (SAE net): 395 bhp @ 6000 rpm
Torque (SAE net): 400 lb-ft @ 4000 rpm
TRANSMISSION: 4-speed automatic
Old Feb 3, 2011 | 12:38 PM
87silverbullet's Avatar
Lets put it like this dude, the TBSS only come with an ls2. If it has an lq9 which only came in the Escalades, Denali's and the SS Silverado's, then you bought a bastard child.
Old Feb 3, 2011 | 12:40 PM
xtreme2001's Avatar
werd,couldnt have said it better
Old Feb 3, 2011 | 12:52 PM
2nd of all, I think ls2's in TBss's are 58x crank reluctor and lq9 is a 24x crank reluctor. If somebody put an lq9 in it they sure did go thru alot of trouble. Only the Gto still had 24x reluctor ls2's.
Old Feb 3, 2011 | 03:08 PM
The early TBSS was 24x. 2007 went to 58x, according my GM literature.
__________________
Old Feb 3, 2011 | 05:34 PM
The 01 Camaro SS is the 2nd car that I have owned with an LS1 motor in it, so I do know a little about the LS motors. The Trailblazer SS does have the LS2 in it, but what was throwing me off was the different looking intake manifold that is used on the Trailblazer than that for the Corvette. Oh by the way xtreme2001 the Trailblazer SS is an AWD and not a 4WD. Here is a link describing the the two types of drives: http://en.wikipedia.org/wiki/Four-wheel_drive
Old Feb 3, 2011 | 05:58 PM
xtreme2001's Avatar
it was copied and pasted.....here is the full page
http://www.caranddriver.com/reviews/...t/specs_page_2
Old Feb 4, 2011 | 08:09 PM
Jeff Smith's Avatar
simple to do>>Take pictures on the motor whatever your vehicles.It would be biggest helpful..The pictures worth 10000000 words...
