Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
388 stroker ?
Old May 8, 2011 | 06:26 PM
dkcoleman01's Avatar
Cool 388 stroker ?
I am wanting to build a 388 stroker for a dd. It will be going in either a 63 impala or an el camino. I have a stock 350 with a good 400 crank, so what kind of bang for the buck goodies can I use for this build. I am looking for great hp and torque. Thanks
Old May 9, 2011 | 11:41 PM
rustmaro's Avatar
You could use a set of Vortec style heads but would have to use a Vortec style intake due to the different bolt pattern. These heads have a 64 cc chamber and outflow the old "camel hump" heads. They are pretty cheap also. You can get them from a Chevy dealer new.
They would make excellent torque on a 383 and good horsepower for a DD.
Old May 19, 2011 | 03:43 AM
CNC BLOCKS N/E's Avatar
If you plan on boring your block .060 I would get it sonic tested first, We don't see many GM blocks for performance builds that would be good at that bore.
Old May 19, 2011 | 07:33 PM
mercccc's Avatar
vortec heads is a great start. im helping a friend with a similiar build. its an 86 regal, but staying with a 350 for now. will have edelbrock etec 200 (vortec based) heads performer rpm vortec intake, dynatech 1 3/4 long tubes, ultimate conveter 3000 stall 4.11's and an ed curtis custom cam 224/236 .601/.603 on a 110 lsa with 1.6 pro magnum rockers. should be a fun street car. a 383 with cast vortecs would be a torque monster.
Old May 19, 2011 | 10:47 PM
LilJayV10's Avatar
What "goodies" are you talking about? Rotating assembly parts, cam, heads?
Old May 21, 2011 | 08:53 AM
gosch383z's Avatar
It all depends on your budget! Get your bottom end rock solid and build up from there. I built a 383 last year that made 506 hp and 489 ft pounds on pump gas, I could use it as a dd if I could afford to put gas in it! Feel free to ask questions if you want.
Old Jun 16, 2011 | 02:42 PM
Cool
Like roller cam set up, heads, pistons, rod I already have a 400 crank.
Old Jun 16, 2011 | 07:28 PM
mm8ls1's Avatar
U probably need to go over to DRR for a ton of info.
