Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
SBC with a 4l60e?
Old Jan 2, 2012 | 09:47 PM
ssnak3's Avatar
Question SBC with a 4l60e?
ok first off i hope this is the right section for this haha...
secondly this isn't the kind of swap that most people do, you know were they have a 1993 s-10 with a 4.3l v6 hooked to a 4l60e and they pull the engine and wonder if they can hook up a SBC to it...
no this is what im dealing with.
I have two s-10s a 1993 and 1984.
the 1993 is 4.3l v6 with 4l60e
the 1984 has a 350 with a medium sized cam and headers carburetated hooked to a 350 turbo trans
I'm having transmission problems in the '84 so i want to put the 4l60e under it
from what i have read, the only way to do that is either go manual or buy a ridiculously expensive shift control most of which are more than $800
so if you guys would please help me and my dad out i would appreciate it...
and if it cant be done i will be selling the tranny and v6 if anyone is interested they both have under 30k miles
Old Jan 2, 2012 | 09:48 PM
ssnak3's Avatar
v6 is for sell regardless if i can do the swap or not
Old Jan 4, 2012 | 06:12 AM
ssnak3's Avatar
bump....
Anyone???
Old Jan 9, 2012 | 12:31 AM
Big Al's Avatar
Why not use a 700R4? Same transmission with out electronic valve body. Google and you'll find more info than you want
Al 95 Z28
Old Jan 11, 2012 | 04:44 PM
93Z2871805's Avatar
Veteran: Air Force
Al 95 Z28
This..
I'd drop the 4L60E in favor of a 700R4.
Old Jan 12, 2012 | 06:51 PM
ssnak3's Avatar
ummm.... because i dont have a 700r4 i have the 4l60e and need to use it
Old Jan 13, 2012 | 10:24 AM
camaro1185's Avatar
Don't quote me, but yes you can. It has been done, I know a few people over at TGO have done it. You need a stand alone controller for the tranny, and I think it will mostly bolt up to the back of the engine, but IIRC you will be missing a bolt.
Old Jan 16, 2012 | 03:52 PM
ssnak3's Avatar
everything bolted up correctly with a few mods to the cross member but i need away around the 800 dollar standalone shifting control unit
Old Jan 16, 2012 | 04:21 PM
sideways87's Avatar
Last issue of Car Craft or Hot Rod they did a test of a bunch of trans controllers. think some of them were a little cheaper.
Old Jan 31, 2012 | 07:39 PM
prodigy86's Avatar
You can use a compushift system or TCI controller but by the time you do all that you could have bought a 700r4 or 200r4.
Old Feb 11, 2012 | 09:59 AM
niceguyyy01's Avatar
I found a controller for 599. Google it. That is the only way to make it work.
