496 8.1L shorty header question
i just picked up a 2006 sierra with the 8.1L. I have a minor exhaust leak on passenger side due to the rear most stud being snapped off. I'm contemplating my options and wondering if/when I do the repair, what are the pros/cons of new exhaust headers?
I was looking mainly in summit and there's a handful of them, by JBA, edelbrock, hedman. Some advertised as 409 stainless, I think all of them shorty headers, and not tuned. I'm not looking for more power, I just want the truck to be reliable with no chance of exhaust leaks ever again, and should i have a problem not have to worry about cracked rusted broken ****.
If i chose aftermarket headers, do they typically fit directly in place of the stock exhaust manifold? And would they cause any computer/sensor issues ?
Fix the stock system. Going to headers is going to be lots of work on your truck, and you are going to want to add a second pipe, another CAT and all the other stuff. And then there is the O2 sensors and so on and so on. The stock system is fine for a stock 8.1 as they are tuned to be almost dead.
Something to watch out for is the drivers side motor mount. It breaks and the fan touches the shroud. or it did on my 02. Price it and when you get up off the floor remember I warned you. My 8.1L has been good to me so far. Hope yours is too.
Al
Al
header swap
Hedman and JBA have headers that bolt right up to replace stock exhaust manifolds. Everything about using headers is positive. Only downside is heat. Using header wrap or a quality stainless steel T-304 ceramic header (not the 409 stainless) will take care of the heat issue. Using quality stainless steel fasteners, gaskets and a header with thick flanges, will give you a good seal. I prefer using studs instead bolts
