lt4 hot cam in a non roller pre 80 bloc?
Pictures, year etc would help
They sell conversion lifters you will probably have to use a cam button since you cant retain it in the block like they do in the newer blocks
http://www.facebook.com/photo.php?fb...type=3&theater
The factory roller cams have a smaller bolt pattern. You need an 87-Up timing set. You also need retro fit lifters ($450+)
I have everything you need if you want to make the swap, pm me
thanks but I have a set. even answered my own question but i figured i might as well post pictures and updates so people will know they did not waste their time with helping me. but thanks really
You also need a place to put the retainer plate!!! Not going to work the older blocks.
I have found a great and cheap workaround for the issue. So you anyone can install a factory roller in a nonroller block. I have to post so others will know
http://forums.corvetteforum.com/c3-t...onversion.html
