break in oil?
There is a pervasive myth in the aviation piston-engine world: the myth claims that in order to break-in a new or freshly overhauled engine or cylinder, straight mineral oil must be used during the break-in period. The term "straight mineral oil" refers to oil that does not contain the ashless dispersant chemicals found in AD or ashless dispersant oil.
Every mechanic has been told from the beginning of time that engines must be broken in on mineral oil. The reasoning behind this claim is that when an engine is run for the first time, it is necessary for the piston rings to seat themselves to the cylinder walls. Properly seated rings provide a fit that keeps compressions high and oil consumption low. Mineral oil, it is claimed, allows seating to occur because it isn’t so slippery that rings won’t be able to wear off the microscopic metal mountain peaks that populate the material that makes up the steel cylinder walls. This part is true. The rings do have to seat, by wearing smooth the metal peaks.
Ashless dispersant oil, the myth says, is too slippery and too good at preventing wear to allow the rings to seat properly. We have all heard this, it gets passed from mechanic to mechanic, and it even sounds kind of logical. Theoretically, AD oil contains some special chemical that gives it more lubricity and greater film strength than straight mineral oil.
But this simply isn’t true.
We build high performance engines and we do it with specific procedures and with rings that require and absolutely do respond to certain running parameters during initial break-in with one of those parameters being the type of oil used. It's acceptable for you to disagree and have your own opinion, but to come in here and call it nonsense and completely disregard the need for proper break-in in any and all applications no matter what honing procedure was used, what the rings are made out of, and what the parts manufacturers have found to be best for their own parts. . .well that's simply ignorant nonsense.
We build the engines in question. We use the parts in question. Based on our experience with the application and parts in question, proper break-in is required. There is a reason that we supply break-in oil with our custom shortblocks at no charge to the customer.
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
You dont do custom work like this if i fell off a turnip truck last week. And what is your expertise in the automotive field DIRTY BIRD. Thank you so much for your kind words i will remember them always. Have to go engines are waiting for me Thanks
