Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
break in oil?
Old Jul 9, 2012 | 12:00 AM
GiggleJuiced_SS's Avatar
Default break in oil?
so im gettin my rotating assembly balanced for my new 383 stroker. so i should be puttin it together within two weeks or so. i spared no expense in this build so i was just wondering what guys have run for the break in period. here's the motor
383 Gen I block 4BM
11:5 to 1 Compression
Probe forged pistons
58cc aluminum heads, 2.02/1.60 valves.
Solid roller cam, roller lifters, 1.7 roller rockers (all comp cam's valvetrain even springs/timing chain)
Forged Scat crankshaft and rods
Arp bolts in everything.
i think thats it lol. so what do you guys run for break in oil on your new motor setup?
Old Jul 9, 2012 | 05:10 PM
ZONES89RS's Avatar
In-Zane Moderator
Used to run diesel oil before they robbed the good stuff out of it, now there are break in oils available.
Old Jul 9, 2012 | 09:02 PM
tom falco's Avatar
Break in oil??? Never heard of it!!!!
Old Jul 9, 2012 | 10:06 PM
01tam6's Avatar
Just run something non-synthetic and you will be fine. If it was a flat-tappet cam I would suggest the comp-cam oil additive but with your roller you will be fine.
Old Jul 9, 2012 | 11:38 PM
i hope you're jokin
i was thinking just normal non-synthetic castrol oil. then switch after a few hrs on the motor. i just like to get opinions on ppl experiences.
Old Jul 10, 2012 | 04:48 AM
tom falco's Avatar
Several cars come from the factory with synthetic oils from the factory!! Porsche for example
Old Jul 10, 2012 | 07:54 AM
Adam1203's Avatar
or all the new ls motors like the camaros and corvettes come with mobile 1 synthetic right from the factory.
they do make break in oil. But I dont think it is needed.
Old Jul 10, 2012 | 01:18 PM
1dirtybird's Avatar
I like Mobil drive clean 5000 with red line additive for the 1st 20 min of run time. It has a ton of detergents, also use a good filter (I run napa golds on everything I do)
Then change it & filter, run for 500 miles or so w/ what ever you use w/ the other half of the redline additive.
My **** dont break so it works for me. (I also assemble all my engine jobs)
Old Jul 10, 2012 | 02:46 PM
tom falco's Avatar
Nope not joking!!
You should break in your engine with conventional oil, then switch to a synthetic oil like Mobil 1.
Reality:
You can start using Mobil 1 in new vehicles at any time, even in brand new vehicles. In fact, Mobil 1 is original equipment (it is installed at the factory) in:
Acura RDX
Aston Martin DB9, DB9 Volante, DBS, DBS Volante, Virage, Virage Volante, Rapide
All Bentley Vehicles
Bristol Fighter
Chevrolet Camaro SS
Chevrolet Corvette Z06, ZR1 and Grand Sport Coupe
Chevrolet CR8
Chrysler 300C SRT-8
Dodge Challenger SRT-8
Holden HSV
Ilmor MV-10 710 Marine Engines
Lexus LFA
Mercedes-Benz AMG Vehicles
Mitsubishi Lancer Evolution
Nissan GT-R
Opel Insignia
All Porsche Vehicles
All S&S Motorcycles
Saab 9-3 TTiD
Vauxhall VXR8
Viper Motorcycles
One of the myths surrounding synthetic oils is that new engines require a break-in period with conventional oil. The fact is, current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design the high-performance cars listed above, Mobil 1 can be used starting the day you drive the car off the showroom floor.
Old Jul 11, 2012 | 01:21 PM
well, technology is alil different today. the newer motors do come with synthetic, i know that. im pretty sure my SS did. i just dont feel like spending thousands of dollars just to spin a bearing right after its put together.
Old Jul 11, 2012 | 02:49 PM
tom falco's Avatar
Why would you spin a BEARING???? That makes no sense. If you spin a bearing it has nothing to do with the oil??? I am not getting what you are saying!!!
Old Jul 12, 2012 | 11:59 AM
i was just throwing out an idea. but nvrmind i have my answer.
Old Jul 12, 2012 | 02:00 PM
ZONES89RS's Avatar
In-Zane Moderator
I used to beat my motors for a week with regular oil, then switch if i wanted to to synthetic after a month. Synthetic can prevent proper ring seating and what not. So i made sure it was bet in.
Old Jul 12, 2012 | 03:43 PM
tom falco's Avatar
WOW do you not realize 2 dozen and counting brand new cars come from the factory with SYNTHETICS.
__________________
Old Jul 12, 2012 | 03:50 PM
1dirtybird's Avatar
And please look up all the TSB's for oil consumption problems on some of those lmao.
Also alot of high end car manufactures fire their engins or cold run them before they install them. that will also break in/ seat the rings. Check out BMW they do it to ALL their engines.
Old Jul 12, 2012 | 04:00 PM
1dirtybird's Avatar
The biggest reason for "break-In oil" is when you build an engine there is dirt, fresh metal shavings from new parts (springs bearings ect ect ect) lint and an excessive amount of abrasive break-in lube. All those things are collected in the oil and filter during the first heat cycles. Why spend the money on synthetic for this reason?
Old Jul 12, 2012 | 04:13 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
__________________
The build/honing process and ring materials etc vary between a rebuilt shortblock with aftermarket parts vs a factory assembled/stock parts shortblock. The end goal for the build differs as well. All of that makes for varying needs and procedures both during the build and during initial run time. What the factory does is not one size fits all.
We supply Joe Gibbs break-in oil with all of our custom shortblocks.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jul 12, 2012 | 07:31 PM
tom falco's Avatar
Ssssxxxxxxxx
Old Jul 12, 2012 | 07:35 PM
tom falco's Avatar
This answer is straight from the MOBIL ENGINEERS!!!
Is it true that new engines need break-in periods using conventional motor oil?
That is a myth. In the past, engine break-in was necessary to remove metal flashing or any other abrasive material left inside the engine after machining, as well as to allow the valves and rings to "seat" properly. Today's engines are built with much tighter tolerances, much improved machining, and under much cleaner conditions compared to the engines of 10 or 20 years ago. Current engine manufacturing technology does not require a break-in period using petroleum-based motor oils.
Old Jul 12, 2012 | 10:26 PM
01tam6's Avatar
Most ring manufacters recommend running conventional oil to help with ring seating. I know that alot of cars come with synthetic but they also get broke in on a dyno and get an oil change before they are put in the car for people to buy. I know there have probably been several engines use synthetic straight from the start without failure. Final honing and ring material also have a factor in how the rings seat. So why not just play it safe and use conventional?
