L98 Ticking/Knocking
CLICK FOR VID
Here is whats happening:
-Very soft when the car is dead cold. Gets louder when warmed up
-Oil pressure is 60 when first stared and 30-35ish at idle even with ticking
-No CEL's.
-No metal on dipstick
-The noise goes away for a split second when shifting from gear to gear (auto tranny)
-Cant really get a good listen using the screw driver on the VC/exhaust manifold etc, but just bought one of those mechanics stethoscope and will check today.
-Also, I have yet to pull the belt off the accessories to see if that does anything.
About 3 weeks ago i got a slight ticking/knocking sound that can be heard really well from under the car, but at one point I thought It might be a lifter or rocker, so I started with removing the DS VC and everything looked good. My friend was telling me he thinks its a low end knock and that I can have a spun bearing. I also thought it might be a TC bolt that backed out or a cracked flexplate, but pulled the inspection cover but everything was tight and no cracks were evident.
Before I go ahead and pull the motor, what else can i check to confirm it is internal engine damage.
Heres another video taken yesterday. As you can see the sound has gotten a lot quieter for some reason. The only things that have changed since the last video is the addition of the catback and I noticed I was really low on coolant in my overflow so I topped that off (I know that didnt do anything to fix the sound, but those are the only changes)
You can hear it toward the back of the PS when I have the camera there.
This coming week, im going to run a compression test on the cylinders.
I ran 3rd gen pedals because they are A LOT beefier than the 4th gen ones, and they are a direct bolt in. With the 4th gen pedals you have to cut the gas pedal off and oval out 3 holes. None of that is "hard" but when you have to keep test fitting it while lying under the dash it becomes a real PITA.
With LT1 T56 swaps people complain that the clutch engages high, but I actually enjoy that. My daily driver clutch pedal engages just like the camaro does so im used to it. The transitions from driving one car to the other will be easy.
Now if only the snow would stop and we got a nice heavy rain I can actually drive my car on the street instead of on the stand........stupid winter!
