BBC build help Recommendations
I have a 7k spending limit to build this engine. I would like to build a reliable 500 hp motor. If I could get closer to 5k awesome as that will allow me to complete the whole drive train. Car has a 12 bolt axle.
So my question is what parts would you buy knowing the budget. How would you build the engine? I will be dropping the block off at the machine shop soon as I figure all the parts out.
What is the casting # of the block & heads?
The plan is to use a TH400. I Have to pick a stall still.
Would you reuse the crank? besides the fact the engine was caked in oil and dirt there was nothing wrong with then engine.
Use a high pressure and not a high volume oil pump to keep from sucking the oil pan dry.
Be conciensus on valve train weight because the hydraulic roller lifters are heavy and it's easy to float the valves. I prefer solid with block restricters.
Get the crank and block checked, and if good, blueprint the block, as in align hone, deck for trueness, and bore w/ torq plates, cast crank is good to about 650 h.p. and 6500 rpm). The balancing is VERY important so have a reputable shop get it done for you. Must replace the rods or at least the bolts!, (weak point for stock engines), with maybe a set of Scat "I" beams, w/ 7/16ths rod bolts. Get Probe forged at 18 cc, (9.7 to 1) or Speed Pro/ TRW forged pistons at 27cc, (10.5 to 1), both sets with rings available for about $500 even, and with the ProComp heads at 119 c.c. and $1000 for the pair = 525 h.p.; with Brodix cast iron heads at $1500 for the pair, losing a couple of points in compression at 121 c.c. = 550 to 575h.p. (and about 80 lbs heavier), or AFR aluminum 280's at $2600 but at 625 h.p.! (aluminum allows for more compression with less chance of detonation), and all with the larger oval port heads, but not as big as the Rectangular port heads! 850 carb is good for power but touchy with an auto, a 750 vacuum secondary would be better and get better mileage as well. Get a smaller cam, at 112 or 114' lobe centers and maybe 525 to 570 lift and at .050 is about 220 to 230' duration with old style hydraulics and don't forget the additive for breaking in the cams!
These are my general idea's and I am not an engine building "GURU", but I have been doing these BBC's since 1968 with my first Camaro. :-)
Raymond
a few parts like intake/carb you can find cheap on craigs list too to lower costs... should be around $5350.00 using name brand quality parts. A few extra parts needed like gaskets..but you get the jist of it. Stay away from Procomp junk, Flat tappet cams and no name parts.Block fully machined about $600
http://www.summitracing.com/parts/sc...05bi/overview/ $1392.00
http://www.summitracing.com/parts/edl-50459/overview/ $1850
http://www.summitracing.com/parts/hr...5-12/overview/ $280
http://www.summitracing.com/parts/hrs-91167/overview/ $370
Pushrods $125
http://www.summitracing.com/parts/edl-7161/overview/ $125
http://www.summitracing.com/parts/qf...0-vs/overview/ $417
http://www.summitracing.com/parts/cc...1-16/overview/ $170
Al 86 IROC, BBC, Toploader 4 speed, 9" Ford.
270 or so hydraulic flat tappet cam, Comp makes an LS6 hydraulic Nostalgia Plus thats like 1800 to 6800 or so with the LS6 sound/idle. RPM air gap intake. Headers for your application. Standard volume oil pump. I like pans with a little more oil capacity. Normal bearings and tolerances. Roller tipped rocker arms. Have the connecting rods re-sized with ARP bolts. Balance for new pistons, stay around 9 or 9.5 - 1 compression ratio. If you keep it as a 454, go with forged pistons, like the L2465 (they are similar to what comes in current crate engines without the crappy metric rings). Cast crank will stand as much power as the block. Two bolt blocks are hell for stout.
If you wanna blow $1200 or so, go for a 496 kit, which is 4.25 inch stroke. Same heads with the big valves and intake.
The compression in the area of 9 - 1 will make the 450-500 mark real easy, with enough room for some nitrous and be as dependable as a sledge hammer.
