Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
5.0 TBI question
Old Nov 21, 2004 | 06:12 PM
Wicked_Hugger99's Avatar
Default 5.0 TBI question
its a Chevy 305 TBI & came w/ 170hp stock. im looking to add around 30-40hp. Do you think i can do it with the following parts: K&N, TB spacer, removal of egr-smog stuff, 160 stat, march pullies, Heddman full length hedders into custom 2 1/2in or 3in x-pipe with turn downs, Edelbrock Power package for TBI motors which is Edelbrock performer manifold & Edelbrock cam .420/.442 204/214 LSA unknown but guessing 114 and some dyno tuning.
Old Nov 21, 2004 | 07:00 PM
gen 3 bu's Avatar
egr will not affect wot performance
i would suggest the afr 180 cc heads, a crane "2030" compucam, full length headers, 2-1/4 duals with x pipe, holley intake (wider powerband), 2 inch throttle body, and a 160 stat.
the march pulleys made no diff on my 355 tbi, the tbi spacers are limited on a thrid gen f-bod due to hood clearance.
ihave a ported and filled stock tbi truck intake with 2" jegs tbi adapter that runs as well at the track as a ported edelbrock perfomer 4 barrel w/ tbi->4 bbl adapter plate
with all these mods i would highly recomend tuning
Old Nov 21, 2004 | 08:56 PM
Cool man, thanks a bunch!
Old Nov 24, 2004 | 08:16 PM
gen 3 bu's Avatar
my brother and i were talking about it today and desided if you are going the far just get a cheap 383 and swap to 195 afr heads and 2-1/2 exhaust.
everything else the same it works good in his tpi car. 13.8 @ 99 with 2.73 gears and no tuning!!
Old Nov 25, 2004 | 08:20 PM
01tam6's Avatar
I would definitely go with the exhaust and the spacer. The biggest hp limiting factor on the tbi engines are the heads they simply don't flow good. A set of vortec heads may be a good option. Stay away from castings 906 as it has a thicker exhaust seat. Just watch your valve guide to retainer clearance as well as coil bind on the springs. TPI specialties or Turbo city would be a good place to start on getting a chip suited to the cam you pick. Comp also has some good TBI cams(put one in my brothers 91). A good ported tb or the 2 inch version will help. Just noticed that you are in Enterprise, I'm over here in Opp. You go to any of the gatherings at Sonic or anything. I'm always up for meeting other car guys. Let me know if you run in to any troubles with your project or know of any car gatherings over that way. Later.
Old Nov 28, 2004 | 11:21 AM
badjuju342's Avatar
Deranged Rat Fink
Holley makes (or did make) a throttle body that had 42% more cfm than the stock unit. I have one on my '95 dually.
Old Nov 28, 2004 | 11:43 AM
fast98's Avatar
the vortec heads are a good choice just stay under .480 valve lift. not all 906 heads are bad only some, u just gotta know what they came off of, only the 3/4 or 1 ton trucks got the hardened seat iirc. o nad stay away from edelbrock cams they suck, if u do go with vortec heads u will need a special intake for them, gm makes one for the tbi as does edelbrock.
Old Nov 28, 2004 | 03:19 PM
[QUOTE=01tam6] Just noticed that you are in Enterprise, I'm over here in Opp. You go to any of the gatherings at Sonic.
Yeah i go up to the "hang out" costal car wash by sonic all the time but havent made it to a cruise-in at hots deli in a while. Actually havent been out for 6weeks due to my broken back. I was thinking either get some kintake/cam package to work w/ the tbi setup or just swapping over to a carb setup w/ intake & cam. Either way, im adding 1 5/8in hedders, ory, and 3in exhaust, gears, Spec clutch, short-throw as well as a crank pulley,custom TBI chip(if dont go w/ carb) and some kinda duel snorkel intake, TB spacer and k&n. I just want to get about 220-225hp at the flywheel and be very reliable. Would i need any fuel upgrades? I set a budget for $2000 so i might not have enough for heads. Which ones are 906 castings? I hear factory 305 H.O. heads are really good and could maybe get a set at a swap meet. Does anyone else besides holley( incase they dont make em anymore cuz i havent found any on the internet) sell better TBI throttle bodies or do you have to home port? Maybe im fighting an uphill
Old Nov 28, 2004 | 09:00 PM
01tam6's Avatar
My mistake fast98 thought all 906's had the different seat. 906 is the last 3 digits in the casting# on top of the head and 906 can also be found cast into the bottom of one of the intake ports. Go to turbocity.com for 454tb's or they have ported stockers and custom chips too. With the parts you have listed you will reach your goal easily.
Old Nov 28, 2004 | 09:37 PM
fast98's Avatar
ya i thought the same thing, i dont know if u heard it the same place i did but i believe it was chevy hi-performance mag or something like that, well a couple weeks later they stated taht it wasn't true of all 906 heads
Old Nov 29, 2004 | 12:06 AM
Would a set of factory 5.0L H.O. heads off of an 84 Z28 work well with the TBI setup and proper intake/cam?
Old Nov 29, 2004 | 12:52 PM
01tam6's Avatar
I'm not familiar with these heads, got a casting# ? I'd say if they have the bigger intake valves(1.84 instead of 1.720) then they will work well.
Old Nov 30, 2004 | 02:52 AM
I was told they have the bigger valves but dunno casting number. I think they came on all the 190hp rated 5.0Liters in the mid 80s.
Old Nov 30, 2004 | 01:09 PM
LOnSLO's Avatar
I used to have a 305 TBI. I did everything you mentioned above except for the cam. I used a 454 SS TBI unit also. The pullies made a big difference (more than the headers).
Old Dec 2, 2004 | 11:13 AM
If i dont do the cam/intake and just did all the bolt-ons i listed w/ a custom TBI chip, how much power do you think id gain over the stock 170hp rating? At least 200hp at the flywheel?
Old Dec 2, 2004 | 01:59 PM
LOnSLO's Avatar
Yea probably. My car was dead even with 5.0 stangs back then, after the mods were done.
Old Dec 2, 2004 | 03:23 PM
Cool 200hp is just fine for a daily driver and should be enough to handle some of the imports and a maybe even few stock GT mustangs from 87-98. im just gonna do that for now and then do the intake/cam or maybe swap to a carbbed 335stroker. How much would a 300hp 335stroker( carbbed) w/ good parts cost to build do you think?
Old Dec 2, 2004 | 09:57 PM
LOnSLO's Avatar
Scrap the 305 rebuild. Just move up to a ZZ series crate motor or something. It would be about the same price anyway, and make way more power.
Old Dec 3, 2004 | 04:00 AM
im just gonna toss on those bolt-ons for now and then look into crates and things!
Old Dec 3, 2004 | 04:37 AM
AdioSS's Avatar
I run the GM_TBI Yahoo group. I'm strongly going to suggest to just buy a cheap 350-400 shortblock.
Personally, I'll be putting a big block in my TBI 305 caprice.
