Cubic Inches
I've got a Dart Little M on the way (iron caps) and I'm wondering how many cubic inches I should build.
I've been looking at doing something like a 377 but with a little more stroke (3.500, 3.562 or something similar). 5.7" rod, and probably a small dished piston.
Motor will probably be 9.5:1 and see a bottle it's first time through then it will get a procharger.
A lot of ppl tell me to do a 420" motor but my friend tells me that it is worthless to throw all the weight around of the extra stroke.
Looking for advice guys!
Thanks
Max Bore 4.185". Max Stroke 3.750"
You won't be dissappointed going more cubes. Believe me when I say I wish I still had my 406 small block. I ended up selling it to my brother for his wagooooon project. That block has great capability...use it. Then the next time a ricer or other car you disslike pulls up next to you, you won't have to worry about if "u got enough".
It's always a nice comfortable feeling.
http://www.chevyhiperformance.com/techarticles/90719/
edit: I know for a fact the Motown blocks can use up to 4.000'' stroke without clearancing the block.
here's a short rundown of my motor. i am changing over to a Fast Times custom turbo spec cam first, but eventually when i get the turbo system on and going, i will freshen the motor and bring the CR down and give the heads some attention. as you can see, mine has a 4" stroke and it did need a little bit of clearancing even with the spread pan rails of the Rocket block. this motor is being copied for the most part from a TT427, also built by the same Fast Times mine was built by, and made just shy of 1200hp and 1000lbft at the flywheel.........on 92 octane!!! you can check it all out at www.montygwilliams.com
-Dart rocket block with splayed billet caps, wide pan rails, raised cam, 4.120 bore and 9.300 deck height!
-Callies 4" stroke internally balanced 4340 crankshaft.
-Crower 6.125" billet rods.
-JE 2618 10.5:1 compression custom FORGED PISTONS.
-Billet solid roller cam.
-.658/.683 lift, 256/264 duration at .050, 108 lobe sep.
-Childs & Alberts rings
-Comp cams offset roller lifters(The expensive ones).
-DART 18 DEGREE HEADS.
-Did I mention it has Dart 18 degree heads!! (untouched, out of the box)
-1.625 comp cams 998-16 valve springs.
-Manley Severe Duty stainless 2.15/1.625 valves.
-Comp cams titanium retainers.
-Crower 1.70:1 ratio stainless shaft rocker system.
-Manley 3/8” pushrods
-Chevy Bowtie nascar type valve covers.
-Siemans 83 lb.hr injectors. (low imp.)
-Billet 2000CFM DOMINATOR THROTTLE BODY.
-ACCELL DFI 7 DIGITAL SEQUENTIAL FUEL INJECTION SYSTEM.
-Holley hall effect crank trigger.
-Holley hall effect phaasable ident distributer.
-WEIAND aluminum waterpump.
-STREET & PERFORMANCE alternator bracket.
-1 7/8” 18 degree headers
-Fluidamper.
-Billet pulleys.
-POWERMASTER racing alternator.
-AGR racing power steering pump.
-TCI racing starter
-16” K&N Dominator air cleaner
-Moroso 7 quart rocket block oil pan
there's some misc. stuff in there because i copied and pasted it from elsewhere. but i hope that helps. and btw, agreed........"there's no replacement for displacement"! especially with TURBO'S!!!!!
later,
Dave
My DART has a 4" stroke with aluminum rods. No clearance problems.
Dave
Dave
Like I said, first time around the motor will see a fogger, then a pro charger. I don't want to over bore if it I don't have to to give myself some room for rebuilds and such.
I'm still up in the air as far as stroke.
it will be 90% street, with the occasional race on the weekends.
Thanks
