Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
sb 400 2-bolt main?
Old Mar 9, 2005 | 11:35 AM
texada's Avatar
Default sb 400 2-bolt main?
How much horsepower with this engine hold. My friend is building it and will be useing some afr 190 runners with a Hydraulic roller 231/237 540+ cam from cam motions and a leginfelter mutiport fuel injection intake with a 1000cfm tb. Will this 2-bolt main 400 sb hold this together? Also, how much power do you guys think this combination will make?
Old Mar 9, 2005 | 11:55 AM
Scott@DrivelineSolutions's Avatar
LS1Tech Sponsor
you might want to put a good set of billet mains on it. I broke 2 400 blocks already and have learned my lesson. The one I have now is billet in all 5 positions and the block is filled up to the water pump. checkout the video new block in action.
http://www.motorcityoutlaws.com/user...y%20passes.WMV
Old Mar 9, 2005 | 01:46 PM
68maro's Avatar
7 Second Club / STF Veteran
at that power rating he will have no problem with a 2 bolt block. beleive me we've got one with 12:5 cr 660 solid roller and a set of track 1's that eats 325 shots regularly. with a cast crank and gm 5.7 rods
Old Mar 9, 2005 | 04:39 PM
CTSV05's Avatar
Just be sure he uses a good set of main studs, and have it align honed/bored to be sure all is well.
I'm running a stock block with splayed caps, no fill and we were well over 6 hundred ponies it was perfect after a teardown after running it for 3 years.
Old Mar 9, 2005 | 04:46 PM
mzoomora's Avatar
14 Second Truck Club
The stock 4 bolt 400's are weak too. Start with a 2 bolt and add the splayed 4-bolt mains. Best way to go IMO.
Old Mar 9, 2005 | 05:45 PM
nosfedgta's Avatar
I went 9.70's with a stock 2 bolt block. Then it cracked, had severe cap walk and some other issues. If you want it to hold you can do some of the above mods or go ahead and buy a dart little m. add up all the machine work, caps, labor and you could have bought a dart little m.....
Old Mar 10, 2005 | 01:02 PM
Mad Dog's Avatar
The 2 bolt block should hold fine up to the 500 hp mark.......that combo should make around 425-450 at the flywheel...
Old Mar 11, 2005 | 04:25 PM
crow2's Avatar
I agree with everyone else on this! THE 400 BLOCK is a high nickel block anyway,2 or 4 really does not make that much difference! Don't be skerd'd!
Old Mar 11, 2005 | 10:06 PM
thebowtieislife's Avatar
the block should be fine, high rpm is what will kill it
Old Mar 11, 2005 | 10:21 PM
PRAY HRD's Avatar
i remember reading an article on converting a 2 bolt 400sbc to a splayed 4 bolt using Moroso's setup i believe. it was supposed to be stronger than a 4 bolt 350 block. only way to go if that's what you've already got. however, NOSFEDGA said it best. add everything up and you can come very close to getting the much stronger Dart block. you will however still need to take it to a machine shop for final prep and to check the trueness of the block, deck, journals, etc. shouldn't be much, but well worth the added comfort of knowing your setup should last a very long time and hold LOTS of power. good luck with the buildup, and post up some more, hmhmmmm, higher quality video footage. that 3rd Gen looks killer and can move!
later,
Dave
Old Mar 13, 2005 | 11:56 PM
camrsz's Avatar
The 2 bolt 400s or a much better then the 4 bolts. due to the larger main journals there is less metal for the outer bolts in a 4 bolt. I would be more concered with the cylinder walls if you plan on making big power. A sonic test of the walls is cheap insurance.
Old Mar 14, 2005 | 12:46 PM
nosfedgta's Avatar
2 bolts are stronger, but her is the problem. CAP walk. The 2 bolt is stronger because of the extra material around them. But a 4 bolt will hole the crank better. Why else do people go to 4 bolt mains and aftermarket 4 bolt mains. Cap walk is a huge problem with 2 bolt mains. I have seen billett main caps also have this problem. BUt these were standar 4 bolt style not splayed. Just a little infor for you here. You will also save money in the future if you go ahead and get some splayed mains in there.....
Old Mar 14, 2005 | 10:26 PM
camrsz's Avatar
This is true, But If i had to choose between a 2 bolt or stock 4 bolt 400 i would choose the 2 bolt. Yes splayed caps would be the best choice.
I belive the two bolt will hold that combo together just fine with studs.
Old Mar 15, 2005 | 02:25 PM
Mad Dog's Avatar
With all of this talk about the Dart blocks, aren't they dry sump only? Kind of an expensive add on. I know the motown blocks are wet sump, but I thought the dart blocks didn'y accept a wet sump system.....I could be wrong.
Old Mar 16, 2005 | 12:53 AM
camrsz's Avatar
you do not have to run a dry sump set up. You just plummbed a filter inline
Old Mar 28, 2005 | 07:23 PM
Kraest's Avatar
It'll definetly hold that. Based on the head/cam combo, I'm guessing around 430 hp at 6300 rpm.
Mike
Old Mar 28, 2005 | 09:49 PM
nosfedgta's Avatar
you can run either one. it has priority main oiling system adn has provisions to run wet or dry..
Old Apr 1, 2005 | 10:18 AM
texada's Avatar
Mike
It seems like a 400ci engine with that set-up wpuld make close to 500HP
Old Apr 1, 2005 | 11:12 AM
NOSjohn's Avatar
Restricted User
Look at that little Gremlin go !! Sorry, previous AMC fan here. Nice 3rd Gen. and FAST !!
Old Apr 2, 2005 | 11:41 PM
BOWTIE's Avatar
I hope it will hold up for you, because that is what I am planning on building. Only difference is I will be de-stroking mine to a 378 cu incher, and hitting it occasionally with a 350 shot. I have often wondered if anyone has come up with main girdles for the SBC like they have for the Furds. That would add a little confidence with out the large price tag of splayed caps and the additional machine work necessary to use them. I agree, I would invest in a Motown block or Little M before I went through the expense of installing splayed caps.
