How much power on a 350 2-bolt main
I think that's kinda a weighted question. I had a buddy that had a 2-bolt block that went 12.1 in his camaro. So he was makin prolly around 400 HP. and it held up well. He beat the living crap outta it and didnt chance the oil once last season! haha. We drained it this year and it had less than 3 quarts in there. But none the less nothing was hurt and the crank was fine. The whole bottom end was stock GM stuff.
Yeah this motor has all been gone through with redone rods, crank, KB flat tops, and ive wrapped it to 7300 once with no problems. I beat the **** out of this motor and i still have no problems. I ask because im adding heads and a cam this season with NOS and just seeing what others have done.
Baltimore Whore
Originally Posted by crow@sdpc
I agree,it would be safe to say 400 would be all we would like to see.If more might look at a cap change!
I had a two bolt, didn't last long, over 6 grand the main caps were probably moving. The bearings wore out quick. I had ARP bolts in it. I would look for a good 880 four bolt. It has a higher nickel content. I beat the heck out of mine and it is still alive. I had forged internals, clevite bearings and gapless rings. Also bought some nascar solid roller lifters to fit the taller lifter bores.
If it is BUILT RIGHT it will last a while. My old one went 12.20's on motor and 10.50.s on a 150 shot.......
88' one piece crank 355cid 9.5comp
stock rods "arp bolts"
stock crank "srp bolts"
prob industries forged pistons
dura molly rings
Internally balanced
comp cams extreme energy roller 274h 224-230@50 502-510 lift.
1.6 rr
edelbrock performer rpm intake
750 holley dp with proform main body
pro topline vortec heads
itrous express spraybarless plate system jetted for 150
hooker 1 3/4 headers
It is still alvie today in my friends iroc running the same et... and it is 3 years old. it has about 10k miles on it, was driven to ny and back, bristol and back and drove it to work for almost a year.
I have run aobut 50 bottles through itand my friend who owns it now has had it over a year and runs 1-2 times a month
Lets just say I have had many people coppy the combo with almost identicle results.....................
that will be 250.00 dollars for the recipe............
dura molly rings
Internally balanced
1.6 rr
When I had my shop we built an engine for a customer that started out as a low-boost engine and then later upgraded to a T-Trim. It made 500+ at the wheels for a long time (about three years) eventually it tore up a piston. But it was a 2-bolt main engine at the time.
I used to work for a well known turbo-kit company and we made 625 w/ twin turbos and intercooler for marine applications. That was done on a cast crank as well. Later, I built circle track (dirt) with two bolts that put out in excess of 525 with cast cranks and 2-bolts. Never broke a cap or crank. On asphalt or concrete with good hook-up, I would limit it to 450.
Most people don't realize that Chevy used two different 4-bolt caps. Most are common grey iron and aren't as stong as the two bolt caps. They also made nodular iron caps (they have an "N" cast into the cap number) that are much stronger. Almost as strong as steel. Hope this helps!
This is interesting to me, because I am running a 2 bolt 383 which is pushing the #'s in my sig, which translates to about 420 hp. I couldnt get a hold of a 4 bolt 880 block when building mine, so I went with the two bolt. Any long term issues I should watch out for?
When you get close to the 450 to 500 Hp level with a 2 bolt you will see signs of micro welding going on between the caps and the block.What is happening is the cap is moving on the block back and forth and transfers metal between the 2 surfaces.The better of the 2 caps is the 512 cap.
mike
mike
