SBC Head Porting
You'll want to take a look at what you're trying to do with the engine to decide which heads to get. In the past the AFR heads work better on a higher RPM engine, and the Corvette/ZZ4 heads work better on engines with mid-range power.
It is better to err on the consevative side than to over size your port and lose the velocity.
But it is correct, the major gains will be seen in the bowl, most are cast very poorly, and the short turn radius.
On your D-Ports, just be careful to visually follow the air out into the header in your mind. Don't remove any more material than needed to gasket match on the floor. Also don't over grind the radius, focus more in the guide area.
Another trick, even tho you add chamber volume, its a good idea to open the chamber up around the intake valve too, this will unshroud the valve, use your gasket and scribe the lines, then put the gasket on your block, and measure how far from the inner edge you can come without going outside the cyl.
My other engine has a Reed cam with .655/.695 lift and 272/282 duration @.050 with a 110 LS. This engine used to have a fogger and a plate on it. The heads on this engine flow 315 CFM@.700.
Its running 6.78 in the 1/8th, and I haven't been back to the 1/4 since I updated my 10 year old coilovers with a set of double adj.
I last ran a 10.77 w/the old shocks but have picked up about 4-6 hundreths in the 60'.
I'd love to see a 10.60 something. The 10.77 was with a 6.84 1/8th. I also learned my alt. isn't keeping my battery at full voltage so I hope this will help as well.
Here is a link to another thread with vids:
Thread
I've ported several sets of LT1 heads with decent success and they are almost identical to a standard SBC head except for the D port exhaust runners. Here is a link to a write-up with detailed pictures I did about 5 years ago. Click on "head porting" on the left side. This is not my website, just my write-up and pictures.
http://members.***.net/gmarengo/
Mike
Mike
Mike, thanks that is going to help me a bunch.
