Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
4th Gen Carbed 350 Swap - Done!
Old May 31, 2006 | 07:06 AM
  #41
raceking33's Avatar
anyone?
Old May 31, 2006 | 04:31 PM
  #42
outlawss's Avatar
What about hood clearance and the carb. I notice some people doing this have to put on a 4 inch cowl hood and turn the carb 90 degrees for clearance. Did your carb fit under the stock hood?
Old May 31, 2006 | 09:33 PM
  #43
raceking33's Avatar
can u use LT1 long tubes on a 350 and work instead of those pacesetters?
Old May 31, 2006 | 10:11 PM
  #44
Strokinit383's Avatar
The pacesetters are lt1 long tubes, and yes they work on gen 1 sbc. My demon is mounted normally with air filter on performer rpm and still fits under stock hood and retains wipers.
Old Jun 1, 2006 | 10:16 AM
  #45
raceking33's Avatar
how long did it take to do the swap?
Old Jun 1, 2006 | 11:50 AM
  #46
Probably 2 months all together.
Old Jun 1, 2006 | 12:30 PM
  #47
Michigan Skip's Avatar
I've noticed that the exhaust ports on the LT1 head are D shaped as opposed to conventional SBC heads that are square shaped. Don't using LT1 headers leak when used on conventional heads and vice versa? I lined up gaskets from bothe headers and you can clearly see that they would. Any comments.? Excellent info, but as always pictures tell a lot more than words do. You guys that have done the swap , could you supply more pics?
Old Jun 1, 2006 | 03:41 PM
  #48
Ive been running these headers for quite some time, along with others and have no leaking problems. I plan on working on the car some more this week, so ill shoot some more pics and maybe a vid.
Old Jun 1, 2006 | 05:43 PM
  #49
Camaro Bird 1987's Avatar
So you didn't have to go cowl hood? Did you have to modify the structure of the hood any?
Old Jun 1, 2006 | 07:51 PM
  #50
I removed the rear center metal bracing of the hood. Just enough for the air cleaner to clear, ill try and snap some pics of that too.
Old Jun 1, 2006 | 09:16 PM
  #51
raceking33's Avatar
hey dotcomslash how long did it take you? and also how hard is it to hook up the engine plate? ans where did u get it from?
thanks
Old Jun 1, 2006 | 10:46 PM
  #52
Dragframe's Avatar
That would be great if you did that. I was considering stripping my hood anyway to get some weight reduction.
Old Jun 3, 2006 | 11:10 AM
  #53
BLWN1's Avatar
What are you all using for a fuel system, sump tank or fuel cell or what? I dont want a cell in the hatch..
Old Jun 3, 2006 | 11:54 AM
  #54
Just use the stock tank and I think you can rig the stock pump to work. Why mess with the cost and hassle of the fuel cell? I don't know about using a mechanical pump with the fuel tank...If anything I would use an aftermarket electric fuel pump.
Old Jun 11, 2006 | 09:31 PM
  #55
So about those pics...
Old Jul 3, 2006 | 11:29 PM
  #56
BLWN1's Avatar
updates...
Old Jul 9, 2006 | 09:34 AM
  #57
fastalz95's Avatar
mallory makes a fuel pressure reg w/return ,so you can run the car on the stock setup
Old Jan 13, 2016 | 01:15 AM
  #58
CamroNewB351's Avatar
i also have a 94 with a 3.4. i intend to rip out. what mounts am i in need of and could you send pics of how you cut out the cowl? for reference?
Old Jan 13, 2016 | 01:37 AM
  #59
what torque plate would be helpful as well i appreciate all info you are willing to give
Old Jan 20, 2016 | 02:13 PM
  #60
tittan1500's Avatar
This thread is like 10 years old.... I did a big block swap so I can give some insight.
I used a BMR K member setup for a SBC/BBC and a standard motor plate from comp engineering to secure the motor.
The BMR K moves the engine to the passenger side by a inch or so to help with header clearance with the steering shaft.
As for the Cowl, I cut it across the full length and stitch welded it back together in one flat piece. I did not want to cut the windshield and patch the hole to the dash so I just run the carb sidways and made an access panel in the top of the dash to pull the distributor from the inside of the car.
